Hinomoto E264
/ Hinomoto E264 #1
GatorFan
Central Florida, USA
Hinomoto E264
Hello everyone!
I am the proud owner of a Hinomoto E264 with a Bulldog loader and Woods bush hog. I have never owned a tractor before in my life. Just a few quick questions from my novice tractor owning self. First, what american model does this machine closely correspond to? Massey something? Second, about how often does one change the engine oil in this tractor? What oil would be recommended? Third, about how often does one change the hydraulic oil? What hydraulic oil is recommended? Fourth, what filter types are there (seems to be four visable?) and when do they need to be changed?Finally ( for now) do I need to grease/oil/lubricate any of the front wheel drive boxes? I found lots of grease fittings virtually everywhere and have greased them but should I remove the access plugs in the front differential and put anything/check anything there?
just for info : the tractor had 74.2 hours since a complete recondition - now has 84 hours - and is in excellent shape. Everything works as it should: I'd like to keep it that way. I got this tractor for my birthday from my terrific wife. Thanks in advance for your help. Little off target but I'm a retired Chef so if I can help you out in that area, my email is evanssnipe@aol.com.
Thanks again.
/ Hinomoto E264 #2
GatorFan said:
Hello everyone!
Massey 1035/1040
50 hours
Shell Rotella
100 hours
Hy-tran (JD-303 Equivalent)
fuel, oil, hydraulic,air
I think i would
Thanks again.
hope this is of some help,if buppy sees yer post im sure he'll help
/ Hinomoto E264 #3
I am at work now. When I get home I'll post the filter numbers if you need them.
Eugene
/ Hinomoto E264 #4
Fuel 3390
Hydraulic 1174
Oil 1346
Eugene
/ Hinomoto E264
Thanks Buppy. Are those Massey Furgeson numbers? Also, what about the air filter?
Thanks again
/ Hinomoto E264 #6
Sorry, these are NAPA numbers. Add a 5 to the front for WIX numbers. I'll have to get back home for the air filter number.
Eugene
/ Hinomoto E264 #7
Air filter NAPA 2276
Eugene
/ Hinomoto E264 #9
I have an E262 which is the 2 wheel drive version. The filters on mine that I have been able to find so far are:
Hydraulic: NAPA 1663, Wix 52663, Baldwin BT260-10, Fram P1656, or Donaldson P556005
Fuel: Wix 33390, Baldwin BF940, Fram P7572 or P7514, and Donaldson P550127
Oil: NAPA 1460, Wix 51460, Baldwin BT215, Fram PH2895, and Donaldson P554408
The air filter I have not got to yet. I just got the tractor a few weeks ago and it was recently serviced. I have not changed any yet and wrote down the numbers on the ones outside. I have not pulled the air filter out of the canister yet to check its number.
The site for the interchange chart for filters is: AMSOIL Master Filter Cross Reference Guide
I hope this can help somebody.
/ Hinomoto E264 #10
Since everyone seems to be posting well on this thread, please reply to this one guys.
Have a Hinomoto N189D tractor and am looking for many of the same type of filters (Air, Oil ,Fuel, Hydraulic -- this tractor appears to have two hydraulic filters) and any info you might be able to supply regarding the hoses (upper and lower) as well as the single fan belt.
Any info you can provide will be greatly appareciated.
Thanks to all in advance!
/ Hinomoto E264 #11
I am a very frustrated owner of a hinomoto e264. I have been trying to find parts for my tractor for the last year. My biggest problem is not knowing what I can use as a substitute front axle parts. My right side barrings are no good as is the wheel hub seal. Can you please tell me how to find parts to work on my tractor? Or what I can replace the front axle with?
Thanks, Frustrated Ray
/ Hinomoto E264 #12
Sorry to hear your plight. I assume you have done a Google search and tried all the Hinomoto parts sellers and salvage yards (gotta ask)? I am going to assume you have an old bearing from the axle that's not totally destroyed. Is it a very unusual type of bearing that can't be matched using inside, outside and width dimensions of the old one? I am not sure what the seal looks like but if it is an O ring or gasket type, that is easily fabricated or replaced or even use of a product like permatex. If that won't do, I have read several posts where tractor owners were able to replace no longer available seals for their machines ( not talking about Hinomotos specifically) by matching automotive seals from the parts store ( probably not likely and certainly going to take some patience on your part and the counter man but if it comes to this, what are your choices?).
You may also want to look at AGCOs parts website. I don't think any of the Massey Ferguson compact tractors cross over directly to the 264 but I would not at all be surprised if some design and parts do. I would probably look at the 1030, 1035,1040 tractors front axle parts diagrams and see if they match the 264's and you may get lucky and be able to attack the parts problem from that angle. http://www.agcopartsbooks.com/PartsBooksN/Viewer/Default.aspx? I like to use the "browse books" option on left hand side of page to see all models)
/ Hinomoto E264 #13
For bearings go to a bearing supply ...they will help you better than "the counter man"
/ Hinomoto E264 #14
Thank you for the information that you have given here. I will definately look on the website that you have listed. And thank you for given me numbers to start with.
/ Hinomoto E264 #15
Bearing suppliers can usually take the old bearing and either cross match the numbers, or they can get enough dimensions off of it to come up with a replacement. I have done this numerous times with an assortment of Textile machines and old box presses,
Here in NC there is a chain called Dixie Bearings, but there are many other chains out there. The same places usually have a supply of seals too.
/ Hinomoto E264 #16
I thank you for the post you sent to me. I will do just as you suggest. But, I have run into yet another problem. Now it seems that my tractor needs a whole new front end. Any ideas as to what I can use as substitution parts for the front axle??? I have been told that I can use a massey ferguson front but, I am not sure that the information was correct.
/ Hinomoto E264 #17
Most of the FWD parts are no longer available. I have several Hinomoto parts tractors & also have made some Hinomoto FWD parts. Let me know what you need & I may be able to supply the parts you need.
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2015 Honda Accord Sedan (A64557)
2015 Honda Accord...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
2018 AUTOCAR XPEDITOR GARBAGE TRUCK (A63276)
2018 AUTOCAR...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
