Hinomoto E264
   / Hinomoto E264 #1
GatorFan
Central Florida, USA
Hinomoto E264
Hello everyone!
I am the proud owner of a Hinomoto E264 with a Bulldog loader and Woods bush hog. I have never owned a tractor before in my life. Just a few quick questions from my novice tractor owning self. First, what american model does this machine closely correspond to? Massey something? Second, about how often does one change the engine oil in this tractor? What oil would be recommended? Third, about how often does one change the hydraulic oil? What hydraulic oil is recommended? Fourth, what filter types are there (seems to be four visable?) and when do they need to be changed?Finally ( for now) do I need to grease/oil/lubricate any of the front wheel drive boxes? I found lots of grease fittings virtually everywhere and have greased them but should I remove the access plugs in the front differential and put anything/check anything there?
just for info : the tractor had 74.2 hours since a complete recondition - now has 84 hours - and is in excellent shape. Everything works as it should: I'd like to keep it that way. I got this tractor for my birthday from my terrific wife. Thanks in advance for your help. Little off target but I'm a retired Chef so if I can help you out in that area, my email is evanssnipe@aol.com.
Thanks again.
   / Hinomoto E264 #2
GatorFan said:
Hello everyone!
Massey 1035/1040
50 hours
Shell Rotella
100 hours
Hy-tran (JD-303 Equivalent)
fuel, oil, hydraulic,air
I think i would
Thanks again.
hope this is of some help,if buppy sees yer post im sure he'll help
   / Hinomoto E264 #3
I am at work now. When I get home I'll post the filter numbers if you need them.
Eugene
   / Hinomoto E264 #4
Fuel 3390
Hydraulic 1174
Oil 1346
Eugene
   / Hinomoto E264
Thanks Buppy. Are those Massey Furgeson numbers? Also, what about the air filter?
Thanks again
   / Hinomoto E264 #6
Sorry, these are NAPA numbers. Add a 5 to the front for WIX numbers. I'll have to get back home for the air filter number.
Eugene
   / Hinomoto E264 #7
Air filter NAPA 2276
Eugene
   / Hinomoto E264 #9
I have an E262 which is the 2 wheel drive version. The filters on mine that I have been able to find so far are:
Hydraulic: NAPA 1663, Wix 52663, Baldwin BT260-10, Fram P1656, or Donaldson P556005
Fuel: Wix 33390, Baldwin BF940, Fram P7572 or P7514, and Donaldson P550127
Oil: NAPA 1460, Wix 51460, Baldwin BT215, Fram PH2895, and Donaldson P554408
The air filter I have not got to yet. I just got the tractor a few weeks ago and it was recently serviced. I have not changed any yet and wrote down the numbers on the ones outside. I have not pulled the air filter out of the canister yet to check its number.
The site for the interchange chart for filters is: AMSOIL Master Filter Cross Reference Guide
I hope this can help somebody.
   / Hinomoto E264 #10
Since everyone seems to be posting well on this thread, please reply to this one guys.
Have a Hinomoto N189D tractor and am looking for many of the same type of filters (Air, Oil ,Fuel, Hydraulic -- this tractor appears to have two hydraulic filters) and any info you might be able to supply regarding the hoses (upper and lower) as well as the single fan belt.
Any info you can provide will be greatly appareciated.
Thanks to all in advance!
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
JOHN DEERE Z920M LOT NUMBER 238 (A53084)
JOHN DEERE Z920M...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2018 INTERNATIONAL LT SLEEPER (A52576)
2009 Volkswagen Jetta Sedan (A51694)
2009 Volkswagen...
