HINOMOTO E2004 WATER PUMP
/ HINOMOTO E2004 WATER PUMP #1
limeric
CAN YOU PLEASE HELP ME L SENT THE WATER PUMP AWAY TO BE REPAIRED AND THEY LOST IT THERE RESPONSE WAS THAT THE HOUSING WASNT ANY GOOD SO THEY DONT CARE HAVE NOT BEEN ABLE TO MATCH OR GET ANOTHER CAN ANYBODY HELP OR KNOW SIMILAR PUMP
/ HINOMOTO E2004 WATER PUMP #2
You can try some AGCO dealers but I dought you'll have any luck. It's the same as a MF1030. Len Shaeffer, who posts on here frequently can get you one.
Eugene
/ HINOMOTO E2004 WATER PUMP #3
I should be able to get you a new pump for you.
L RANG THE MF DEALERSHIP AND GOT THEM TO FAX ME THE WATER PUMP FOR THE 1030 AND THOUGH ITS A LITTLE LIKE IT ITS NOT THE SAME AND HAS SOME EXTRA FEATURES MAKING IT UNSUITABLE SO IF YOU HAVE ANY OTHER SUGGESTIONS WOULD LIKE THE INPUT AS LM STILL AT A LOSS END
REGARDS DAVID:)
THANK YOU WOULD IT BE POSSIABLE TO POST PIC OF IT SO L CAN SEE IT FIST AS THE MF1030 IS NOT THE SAME
REGARDS DAVID
/ HINOMOTO E2004 WATER PUMP #6
Too many tractors to stock all parts. I order parts using the Hinomoto part #.
THANKS FOR THE RESPONSE LEN THE MOTOR IS CS112 DIESEL ENGINE MAKE HINOMOTO E204 WE LIVE IN AUSTRALIA HOW MUCH IS IT CAN WE HAVE YOUR NUMBER TO CONTACT YOU DO YOU NEED A PIC OF TRACTOR AS WE DONT HAVE A PARTS BOOK
REGARDS DAVID
/ HINOMOTO E2004 WATER PUMP #8
The E204 & E2004 use different waterpumps. I can supply a pump for your tractor. You can email me for pricing.
The tractor is a e204 and the motor is a cs112 is there a tractor that uses the same water pump that l might be able to get here in australia l really appreciate that you are able to get one if not
regards david
CATERPILLER 326 EXCAVATOR (A65053)
CATERPILLER 326...
Case International 21' Disk Harrow (A64127)
Case International...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
