Hinomoto E14 Hydro Prob.
/ Hinomoto E14 Hydro Prob. #1
beck8120
pump is making noise and creeping up and not responding at all sometimes. seems like getting preasure/fluid then not appears to be starving for oil...has 675 hrs. it always had some noise in pump just when lifting only. but always worked befor!!! had 3 yrs now and just put pto seal in. it has lots of fluid,not low at all. dont have any manual or book..does this have a pick up strainer/screen at all and if were location. Filter location? have looked but seem to see any. Any help would be great..and or a location to find something on this on the Net. This could be just a simple problem or a total replacement of pump that I dont need at this time..
/ Hinomoto E14 Hydro Prob. #2
I have an AC 5020 which is somewhat similar to an E-23 and I do have a strainer/filter on my machine, its location is on the left side ( clutch pedal side ). Mine is a round plate with 2 bolts holding the cover on, basically located on the opposite side/level of the suction line, obviously you need to drain the fliud to remove it from the machine, it serves as both a filter and strainer on the 5020. Hope it helps and its just a clogged filter/strainer,, good luck.
Hey js5020,,went out and found it round 1pm..it is right were ya said it was ,, plugged up,cleaned and works better than it did since I bought the the tractor..Thanks..
/ Hinomoto E14 Hydro Prob. #4
Glad it was just the strainer,, I have had mine since 84 and it has been a very reliable piece of equipment. Enjoy!
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
MIRRORS, MARKER LIGHTS, SWITCHES (A64276)
MIRRORS, MARKER...
2014 Chevrolet Express Shuttle Bus (A64556)
2014 Chevrolet...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
2011 FORD F-350 FLATBED DUMP TRUCK (A64278)
2011 FORD F-350...
Chariot Floor Scrubber (A64194)
Chariot Floor...
