Hinomoto C144 injection pump oil change.
   / Hinomoto C144 injection pump oil change. #11
Then I stand corrected & humbly apologize.. I have NEVER seen a drain on a PFR style system..
If you could.. would you snap a pic of the drain & fill?? I would appreciate it..
This is one of the reasons for the short life on these pumps many people don't understand that they are not pressure fed from the engine and that they need to be refilled separately. I check the oil in the pump every time I change engine oil on my MF1010. So far so good.
   / Hinomoto C144 injection pump oil change. #12
Took 20 min to change mine.
Pulled fuel filter & hose > made cardboard funnel > removed drain bolt > drained > pulled fill cover > flushed a little with some random clean oil > drained > filled with 6oz of 30w and a little Lucas oil stabilizer > reinstalled cover > hooked up fuel and bled > test run. 20190913_174044.jpeg20190913_174052.jpeg20190913_174103.jpeg
   / Hinomoto C144 injection pump oil change. #13
Hello! I'm new here and in the field of tractors..I recently bought a hinomoto c144 engine cs86...but..it needs a lot of repairs...Please I need a user manual..if you have any or tell me where I can find it..I've been looking for a few days and..nothing...please....Thank you!
   / Hinomoto C144 injection pump oil change. #14
Hello! I'm new here and in the field of tractors..I recently bought a hinomoto c144 engine cs86...but..it needs a lot of repairs...Please I need a user manual..if you have any or tell me where I can find it..I've been looking for a few days and..nothing...please....Thank you!View attachment 2668052
Solved ..now I have both the repair manual and the parts manual ...Thank you ~~
LATE MODEL JOHN DEERE EQ. AUCTION LOT NUMBER 1 (A53084)
LATE MODEL JOHN...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
1261 (A50490)
1261 (A50490)
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
