Hinomoto BEST E15 parts
   / Hinomoto BEST E15 parts #1
Travis_R
Livingston Parish, LA
Yanmar YM2500
Anyone know where to get a PTO shaft seal for this tractor? It's leaking so bad the tractor can't be used...
Also, it came with a Japanese tiller but don't have a model number on it. The tiller's driveline will not connect to the tractor's PTO shaft. It's too short. Neither the tractor or tiller has a 3 pt. hitch.
Where can we get parts and what do we need to get this thing going??
Thanks!
   / Hinomoto BEST E15 parts #2
Any Bearing/Bushning/Seal shop would have or could get most all the seals on that machine, check the yellow pages online under bearings. Sounds like someone threw in a tiller with the purchase that isnt the matching 2 point tiller that originally came on that tractor. Sometimes 2 point tillers can be converted to 3 point, its alot of work though.
   / Hinomoto BEST E15 parts #3
I can supply you with parts.
   / Hinomoto BEST E15 parts #4
Check the shaft if its scored it will eat the new seal.
some times you can shim seal out to a new surface on shaft
or use a speedi sleeve and the appropriate seal
416A8CE880CF4B59BE6B74FCD7B4EF4C.ashx
Speedi-Sleeve shaft repair kits
tom
2019 Honda CRF1000L Motorcycle, VIN # JH2SD0409KK300478 (A51573)
2019 Honda...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
(APPROX 250) UNUSED TRAFFIC CONES (A51248)
(APPROX 250)...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2002 Ford F-150 Pickup Truck, VIN # 1FTRW07332KD61848 (A51572)
2002 Ford F-150...
