Hinomoto BEST E15 parts
   / Hinomoto BEST E15 parts #1
Travis_R
Livingston Parish, LA
Yanmar YM2500
Anyone know where to get a PTO shaft seal for this tractor? It's leaking so bad the tractor can't be used...
Also, it came with a Japanese tiller but don't have a model number on it. The tiller's driveline will not connect to the tractor's PTO shaft. It's too short. Neither the tractor or tiller has a 3 pt. hitch.
Where can we get parts and what do we need to get this thing going??
Thanks!
   / Hinomoto BEST E15 parts #2
Any Bearing/Bushning/Seal shop would have or could get most all the seals on that machine, check the yellow pages online under bearings. Sounds like someone threw in a tiller with the purchase that isnt the matching 2 point tiller that originally came on that tractor. Sometimes 2 point tillers can be converted to 3 point, its alot of work though.
   / Hinomoto BEST E15 parts #3
I can supply you with parts.
   / Hinomoto BEST E15 parts #4
Check the shaft if its scored it will eat the new seal.
some times you can shim seal out to a new surface on shaft
or use a speedi sleeve and the appropriate seal
416A8CE880CF4B59BE6B74FCD7B4EF4C.ashx
Speedi-Sleeve shaft repair kits
tom
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2015 John Deere 8245R MFWD Tractor (A53342)
2015 John Deere...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2008 JOHN DEERE 6330 LOT NUMBER 98 (A53084)
2008 JOHN DEERE...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
Electric Mobility Scooter (A51694)
Electric Mobility...
