Hill Climbing Primer
   / Hill Climbing Primer #251
The Dragster wheels spin up right now. Theyre a sacrificial clutch -- at least used to be. Have they gone to a well controlled spin these days.
   / Hill Climbing Primer #252
Do you all realize that at this point you all are now getting into minutiae (the small, precise, or trivial details of something) of this?
Basically it boils down that if you hook to the drawbar (or below axle height) with anything you want to pull and are reasonable about trying to drag it you'll be fine. If you hook to the 3PH with no attachment to the drawbar your chances of an flipover are higher but not guaranteed.
If you link to the top link only of the 3PH you are probably doing it wrong.
So just freakin give it up already.
Which is sillier,,, the discussion continuing or you still reading it??? :D
   / Hill Climbing Primer #253
Shhhh.. we don't want people to know we are still reading it. (well skimming the highlights anyway):D
   / Hill Climbing Primer #254
   / Hill Climbing Primer #255
In the forest area around were I live the only way timber is moved in the forest is by skidding, using a dozer or skidder. Running a vineyard on a steep slop I have to move bins of grapes, 500 lbs. each. I use a four wheel drive tractor and very rarely go up hill as the rear wheels loose traction and going down hill I can drop the load and push it. always in fear of a turn over.
   / Hill Climbing Primer #256
Static conditions only occur if the clutch isn't engaged or the motor is stopped. :thumbsup:
   / Hill Climbing Primer #257
... Which has nothing to do with whether they are predictively identical to a steady drive condition.
larry
   / Hill Climbing Primer #258
larry
Reads good but doesn't really mean anything other than an attempt at confusion! :laughing:
   / Hill Climbing Primer #259
Reminds me of what my First Sergeant always said when I was in Vietnam about dealing with Officers. "If you can't dazzle them with brilliance, baffle them with bulls***". :)
   / Hill Climbing Primer #260
Some will be confused, some will not
It's a complicated subject ;-)
14179 (A55788)
14179 (A55788)
17307 (A55853)
17307 (A55853)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
LOT: (4) Large Wheel Chocks (A59076)
LOT: (4) Large...
Mini Skid-Steer Forks (New/Unused) (A59225)
Mini Skid-Steer...
