High visibility beacons for safer road work
   / High visibility beacons for safer road work #21
I occasionally have to take my tractor onto the road to get from one property to another. Partly because of a chronic problem with my OEM flashers (they keep shorting out), I decided to add a separately circuited set of flashing beacons onto the light bar I built for my tractor.
I just finished installing them, and I have to say I am really impressed by the product. They are sturdily built, and include a flexible base mount that allow the beacon to take a modest hit (tree branches, etc.) and not get damaged. The LEDs are more than bright enough for daytime visibility. And the entire device uses a quick attach system that allow you to remove the beacon without having to remove the base bracket from the tractor.
You can get these on Amazon or at any other online superstore or parts place.
You should try living in Amish country, black buggies with tiny red tail lights, traveling 8mph on a federal highway. The plus side is they usually have about 50 cars following them so that’s pretty easy to see. 😉
   / High visibility beacons for safer road work #22
The way a lot of folks( city folks, I would guess) drive on our rural county roads the only flash they might respond to - 12 gauge shot gun.
MAN - I stay the H**L off our county roads with my tractor. It IS big and it IS heavy - but also expensive to repair.
   / High visibility beacons for safer road work #23
Isn't there a rule about how far you can move a tractor on a public highway before you're required to trailer it? I get behind a tractor every once in a while that will go for miles and miles, even through town.
I suspect that there may be such a rule depending upon the state and the nature of the road. Where we live is quite rural, and the shoulders are relatively wide. I've been passed by a few state troopers in the past, and they've never stop me or even said anything. So I'm guessing it's fine.
   / High visibility beacons for safer road work #25
This time of year maybe 1 in 20 vehicles going past my house during the day is a tractor or spreader. Green 7 and 8 series. Planting prep has begun.
One of the larger farmers in the area told me they keep a supply of mailboxes and posts on hand. :)
   / High visibility beacons for safer road work #26
My Kubota came without a beacon, but with switch on the dash and wiring terminating behind the seat. I fitted an led beacon high up on the outer side of the ROPS but below the top of it, so that it shouldn't get knocked off.
Here in the UK, it's an offence to have one near enough to a turn indicator so that it could cause confusion.
   / High visibility beacons for safer road work #28
I know of no state in the US that limits how many miles you can drive a tractor.
We road travel considerably with tractors and implements usually 3 miles or less,
occasionally 10 miles. But I do know of farmers that will do more distance as needed.
On the issue of the strobes I had one for my Branson and removed it, my flashers are high and work good.
The strobe would interfere with my vision in fog or snow reflecting back into my eyes.
   / High visibility beacons for safer road work #29
During spring planting and fall harvest there will be lots of LARGE tractors using our country roads. I've never had a problem - been out here 40+ years. Just pull over and let them pass.
What really makes me chuckle. City dude & some fancy auto. Going like the Devil is chasing him. Around the corner and for the next five miles - a herd of cows were just driven to the next pasture. MAN - cow **** flying everywhere. Looks good on a shiny car............
   / High visibility beacons for safer road work #30
To the point of farm tractors on the roadway and the lighting required, I looked it up for Colorado-- perhaps your state would be similar.
There is no geographical or time limit (dawn to dusk type of restriction) for farm equipment. If it farms, it goes.
(33) "Farm tractor" means every implement of husbandry designed and used primarily as a farm implement for drawing plows and mowing machines and other implements of husbandry.
Every farm tractor and every self-propelled farm equipment unit or implement of husbandry not equipped with an electric lighting system shall, at all times mentioned in section 42-4-204, be equipped with at least one lamp displaying a white light visible from a distance of not less than five hundred feet to the front of such vehicle and shall also be equipped with at least one lamp displaying a red light visible from a distance of not less than five hundred feet to the rear of such vehicle.
Now here is something funny. I'm only questioned when trailering my tractor, never when roading it. When it's on a trailer I get asked, "Where's your SMM tag?" (In Colorado this is like a license plate for heavy equipment). When roading the tractor, law enforcement just waves as we drive by.
Ford 3550 Backhoe (A47384)
Ford 3550 Backhoe...
John Deere 24" Backhoe Bucket (LOCAL TOWNSHIP) (A50774)
John Deere 24"...
5-500 3 pt Spreader (A50515)
5-500 3 pt...
10ft Fork Extensions (A50322)
10ft Fork...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
