High tensile fence crimp sleeves
   / High tensile fence crimp sleeves #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
I bought a used KIWI crimping tool in the original box. The box had a packet of crimp sleeve.
They are Steel.
Most of them these days are aluminum yes??
Are the steel ones better?
   / High tensile fence crimp sleeves #3
I like gripples!
   / High tensile fence crimp sleeves #4
I used aluminum initially and needed some more so I tried some steel crimps because they are cheaper and they rust quite a bit after about a year. The aluminum are better but more costly. I got mine at TSC.
   / High tensile fence crimp sleeves #5
They are Steel.
I've never used anything but aluminum. But if you are in an area that can get some sea air, I would avoid steel as I can see the possibility of corrosion being a problem
   / High tensile fence crimp sleeves #7
They are Steel.
I think they’re better, but you definitely need the nicopress tool to crimp them.
   / High tensile fence crimp sleeves #10
I’ve never had an aluminum crimp fail.
I have had hogs run through fence lines and break the wire but the crimps always hold.
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
Adams 5 ton Fertilizer Buggy / Wagon (A52748)
Adams 5 ton...
2017 FORD F-650 FLATBED DUALLY (A52472)
2017 FORD F-650...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
