High tensile fence crimp sleeves
   / High tensile fence crimp sleeves #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
I bought a used KIWI crimping tool in the original box. The box had a packet of crimp sleeve.
They are Steel.
Most of them these days are aluminum yes??
Are the steel ones better?
   / High tensile fence crimp sleeves #3
I like gripples!
   / High tensile fence crimp sleeves #4
I used aluminum initially and needed some more so I tried some steel crimps because they are cheaper and they rust quite a bit after about a year. The aluminum are better but more costly. I got mine at TSC.
   / High tensile fence crimp sleeves #5
They are Steel.
I've never used anything but aluminum. But if you are in an area that can get some sea air, I would avoid steel as I can see the possibility of corrosion being a problem
   / High tensile fence crimp sleeves #7
They are Steel.
I think they’re better, but you definitely need the nicopress tool to crimp them.
   / High tensile fence crimp sleeves #10
I’ve never had an aluminum crimp fail.
I have had hogs run through fence lines and break the wire but the crimps always hold.
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2007 Ingersoll...
2015 PETERBILT CLASS 8 CEMENT MIXER TRUCK (A51243)
2015 PETERBILT...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A51039)
Heavy-Duty...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A49461)
2015 Peterbilt 579...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
