High pressure 2720
/ High pressure 2720 #1
wooden
1992/318 & 2010/2720 deere
My High pressure line was shipped on the 2Nd and should be here in 3 to 5 days. According to my dealer in FL this part was re called by JD , so anyone with a 2520 or 2720 bought in late 2010 early 2011 should call their dealer to find out what they need to do.
I am not saying that all these high pressure lines would fail like mine did, but you need to be aware of this and inform your dealer in the event this does happen to your machine. As suspected, the line failed in a welded seam , close to the bend and flair where it goes into banjo fitting at the FEL SVC under the seat. This can fail anywhere in the line if defected. Be sure to look into this.
Wooden
/ High pressure 2720 #2
Thanks for the warning. Tis good to know those things. High pressure fluid on the body can mess you up pretty good.
