High pitch noise from Trans or Rear
   / High pitch noise from Trans or Rear #1
Tractorbill
Alexandria Twp, NJ
Kubota L245DT
I have a Kubota L245DT over 20 years old and just started hearing a noise only when in low reverse gear. All other gears forward and reverse seem to be fine. Can anyone advise me what might be causing this or what to do?
:confused:
   / High pitch noise from Trans or Rear #2
Anytime I hear a noise I usually have to add fluid. Good luck.Hope it's that simple.
   / High pitch noise from Trans or Rear #3
:confused:
Stop using low reverse.:) Sorry, I couldn't resist.:)
Thanks Copperhead. I will check it and add if needed.
And JohnThomas, When using low reverse I can smooth out my driveway better than I could with my scraper. But thanks for the imput.
   / High pitch noise from Trans or Rear #5
I had a high pitched noise like that once in my truck , stopped and let the wife out and the noise stopped . :)
Might be a bearing or like of fluid on one .
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
