high end on R syn 5/40
   / high end on R syn 5/40 #1
big bubba
Elite Member
arkansas
M8540
Members: Every morning I'm amazed at the ignorance of the person standing in front of the mirror, so here goes another......Am considering swithching to Rotella synthetic 5/40 from R 15/40 because of the flow char. in cold weather. But @ 90 degrees for 8 hrs in a hayfield, does the synthetic have comparable cushion on the 40 viscosity end comared to the dyno? After all the dyno rating is "heavier". I'll leave it to the experts. thanks bb
   / high end on R syn 5/40 #2
Bottom line? When its "hot" a 40 weight is a 40 weight is a 40 weight.
5W-40....10W-40....15W-40.
   / high end on R syn 5/40 #3
A 5w40 oil will be more viscous at operating temperature than a 15w40. This is because the viscosity temperature line (or plot) on a 15w40 is steeper. Viscosity drops as temperature goes up.
This would only be true on metal surfaces that are hotter than about 212 F. At 212 F, both the 5w40 and 15w40 will have the same viscosity. The most significant difference would be at say, -40 F/C. The 15w would be like molasses; hereas the the 5w would be like a regular syrup.
Ralph
Thanks Ralph for info...so are you saying that after warm up in summer conditions, both 15/40 and 5/40 will have the same viscosity & cushioning properties, and that the only difference will be in the winter when the 5/40 will have better flow properties? R 15/40 is proven and have broken in my new 70 HP diesel with it. I have also changed the oil at 40 degrees, and it definately is a slow flow....but the local dealer says it's okay all year round....Want to do this new engine thing right and have mortgaged 2 years of my life to purchase it....motor oils are like religion, don't know if you've chosed the right one until it's too late. thanks again bb
   / high end on R syn 5/40 #5
   / high end on R syn 5/40 #6
Ahhh, the case for a 40 weight oil...
Is there one ?
I s'pose if you have something that leaks out 30 weight oil... maybe.
I prefer an oil that flows when cold and "hurries on down" to the pan again and not hang around high in the engine.
I should add that higher viscosity does NOT necessarily indicate higher film strength, butYa all knew that already, right ?
   / high end on R syn 5/40 #7
In engines that were designed for a 40 weight there is a case for it. But more often it seems people use it as a way to maintain oil pressure and extend the life of worn engines, or because they fall into the "thicker must be better" camp.
I'm a believer in running as thin an oil as works properly, and using synthetics any chance I can. But, that's just me...
   / high end on R syn 5/40 #8
I agree with you on the synthetics. I use Hydrotex's hyfilm max 15w-40 and average around 55k between oil change intervals, with an oil analysis program of course. I also have several truckers that swear by it and average over 60k. I pull an oil sample for them as well. It's a group 3 severly hydrocracked and hydrotreated synthetic oil, vs. rotella which is a group 2 synthetic.
   / high end on R syn 5/40 #9
Where might you have heard that Rotella synthetic is group 2? By the way, group 2 base stocks are NOT synthetic. Synthetics start at group 3.
   / high end on R syn 5/40 #10
Bubba,
Does the owners manual call for a 40 weight? I have a much smaller Kubota tractor, but the owners manual calls for 10W 30, and that's what she gets. Dino until 100 hours, then I'll switch to a quality synthetic 30 weight which meets the specs in the manual.
2007 WESTERN STAR 4900 (A50854)
2007 WESTERN STAR...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
(INOP) 2005 JCB 506C TELESCOPIC FORKLIFT (A50459)
(INOP) 2005 JCB...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
1 guard rail (A49346)
