Hiding Zerk
   / Hiding Zerk #1
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
I'm pretty consciencious when it come to keeping my machine greased. Last fall I was greasing the zerk on the rock shaft's right side. It occurred to me that there should be one on the left side as well. Moved a couple of hydraulic hoses and there it was. It hadn't been lubed in the eight years since it was new. It's a pain to get the hoses out of the way so you can get to it.
I finally managed to get a gun on it and proceeded to pump the handle about 12 times without any excess grease squeezing out.
Have I done any damage? The 3pt hitch works just fine.
   / Hiding Zerk #2
Maybe a little excess wear, but I wouldn't worry about it, if it was me.
   / Hiding Zerk #3
if it ain"t falling off, or making a heck of a sqealing noise, it should be ok ;)
   / Hiding Zerk #4
You might think about running a grease tube to that location to bring the zerk out to a more accessible location.
   / Hiding Zerk #6
Where does one get grease tubes? I have a PITA zerk I'd like to make accessible.
Almost any place that makes hydraulic hoses can make what you need.
If you don't need a particularly long one you can also get the flex hose replacement for your grease gun, make one from that. You will have to fab up a bracket to mount the zerk end. KennyV
   / Hiding Zerk
Why can't I fill it. I've pumped a ton of grease into it. Is it squeezing the excess into the hydraulic system?
2010 KMC 3376 Peanut Combine (A55301)
2010 KMC 3376...
Hose Reel (A53424)
Hose Reel (A53424)
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
2022 Adams CLC-1013 Conveyor - New (A55302)
2022 Adams...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
