Hi my name is Hammick and I'm an over-greaser
   / Hi my name is Hammick and I'm an over-greaser #41
You keep your money and the device. I'm all good with what I have. Thanks.
Sounds a lot like me with buying/using a computer,... many years ago.
Now I can't/won't do without!
   / Hi my name is Hammick and I'm an over-greaser #42
I’m not anti Lock & Lube, I’ve looked at them and can see they would be good in many cases. How do they work for U joint zerks? Will they fit?
   / Hi my name is Hammick and I'm an over-greaser #43
I recently greased the PTO u joints on my brush hog with it, worked just fine.
   / Hi my name is Hammick and I'm an over-greaser #44
One pin on the left lift cylinder was dry:eek: It would slide side to side but thankfully had no radial play.
Some how I had never greased that zerk because of its angle it was difficult to get the grease gun to stay attached[no locknlube].
I did manage to pump it full which tightened it right up.
Since I brought it up, I have never seen nor used a locknlube, was just mentioning it an an excuse for not greasing that zerk:eek:
   / Hi my name is Hammick and I'm an over-greaser #45
i used to be an over greaser myself.....until i went to overgreaser anonymous.
after i went thru the 10 step over greaser process and got my Fonzie pin, i spent 8 hours disassembling my loader completely and cleaning out the gobs of grease i had installed in it. spent hours cleaning off the greasy mess and reassembling it. now i only squirt once in each zerk after 8 hours of USE. no more mess and no waste ( after reassembly i did squirt until i saw some bleed by).
tractor looks way nicer. my clothes dont have globs of grease on them when i brush past the loader, and i really dont worry about wrecking anything.
oh..and i have the lock n lube and have NEVER found a zerk it doesn't work on. worth every cent.
   / Hi my name is Hammick and I'm an over-greaser #46
Happy for ya. Still don't want or need one. Useless item in my view.
   / Hi my name is Hammick and I'm an over-greaser #48
I can with all the political pandering I get for money lately.
If you think you can do without a computer, how do you believe that you could be a participating member of TBN.
Snail mail ???
Last time I checked, it seemed that a computer is required!
   / Hi my name is Hammick and I'm an over-greaser #49
Ignorance is bliss they say. Faster and easier for 99% that have used them. Funny why so many would spend $30 on a useless item. :confused3: But stick to your guns!
   / Hi my name is Hammick and I'm an over-greaser #50
Thing is, not many fellas will ever change a position once they take one. Think Fonzie from happy days. "I was wr...wr.. wro.. wron...."
Very very few will change their mind. Or ever take a "well, I will give it a look" or have an open mind. No, it is always "I am right, I said I was right, my mind is made up and nothing on this earth will ever change that." this is just the way most guys (not all) roll.
UNUSED JCT HYD AUGER (A57193)
UNUSED JCT HYD...
UNUSED FUTURE D5T 35" HYD TILT EXCAVATOR BUCKET (A57193)
UNUSED FUTURE D5T...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
2019 Chevrolet Express 3500 Passenger Van (A55852)
2019 Chevrolet...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
