Hi my name is Hammick and I'm an over-greaser
   / Hi my name is Hammick and I'm an over-greaser #41
You keep your money and the device. I'm all good with what I have. Thanks.
Sounds a lot like me with buying/using a computer,... many years ago.
Now I can't/won't do without!
   / Hi my name is Hammick and I'm an over-greaser #42
I’m not anti Lock & Lube, I’ve looked at them and can see they would be good in many cases. How do they work for U joint zerks? Will they fit?
   / Hi my name is Hammick and I'm an over-greaser #43
I recently greased the PTO u joints on my brush hog with it, worked just fine.
   / Hi my name is Hammick and I'm an over-greaser #44
One pin on the left lift cylinder was dry:eek: It would slide side to side but thankfully had no radial play.
Some how I had never greased that zerk because of its angle it was difficult to get the grease gun to stay attached[no locknlube].
I did manage to pump it full which tightened it right up.
Since I brought it up, I have never seen nor used a locknlube, was just mentioning it an an excuse for not greasing that zerk:eek:
   / Hi my name is Hammick and I'm an over-greaser #45
i used to be an over greaser myself.....until i went to overgreaser anonymous.
after i went thru the 10 step over greaser process and got my Fonzie pin, i spent 8 hours disassembling my loader completely and cleaning out the gobs of grease i had installed in it. spent hours cleaning off the greasy mess and reassembling it. now i only squirt once in each zerk after 8 hours of USE. no more mess and no waste ( after reassembly i did squirt until i saw some bleed by).
tractor looks way nicer. my clothes dont have globs of grease on them when i brush past the loader, and i really dont worry about wrecking anything.
oh..and i have the lock n lube and have NEVER found a zerk it doesn't work on. worth every cent.
   / Hi my name is Hammick and I'm an over-greaser #46
Happy for ya. Still don't want or need one. Useless item in my view.
   / Hi my name is Hammick and I'm an over-greaser #48
I can with all the political pandering I get for money lately.
If you think you can do without a computer, how do you believe that you could be a participating member of TBN.
Snail mail ???
Last time I checked, it seemed that a computer is required!
   / Hi my name is Hammick and I'm an over-greaser #49
Ignorance is bliss they say. Faster and easier for 99% that have used them. Funny why so many would spend $30 on a useless item. :confused3: But stick to your guns!
   / Hi my name is Hammick and I'm an over-greaser #50
Thing is, not many fellas will ever change a position once they take one. Think Fonzie from happy days. "I was wr...wr.. wro.. wron...."
Very very few will change their mind. Or ever take a "well, I will give it a look" or have an open mind. No, it is always "I am right, I said I was right, my mind is made up and nothing on this earth will ever change that." this is just the way most guys (not all) roll.
2015 Ford Fusion S Sedan (A55853)
2015 Ford Fusion S...
UNUSED FUTURE 20' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 20'...
2014 Chevrolet Traverse 2LT SUV (A55853)
2014 Chevrolet...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
John Deere 3pt 2 Row Planter (A53317)
John Deere 3pt 2...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
