Hi folks! Wildey Farms here,
   / Hi folks! Wildey Farms here, #1
wildey farms
Southwest Ohio, USA
International, David Brown, New Holland, Kobota
I'm brand new to this thread. I've got an early 70s 450 Case Crawler/Bulldozer that is having fuel problems and while searching for information I came on your group and thought I join. It will run briefly then dies. Still have some more trouble shooting before I give up and pull the injector pump.
   / Hi folks! Wildey Farms here, #2
:welcome:
To TBN Wildey. We are glad that you found us and joined.
How big are your farms and what do you raise besides dust? :D
   / Hi folks! Wildey Farms here, #3
Welcome to TBN and the forum. Suggestion - update your profile and tell us where you are located.
   / Hi folks! Wildey Farms here, #4
:welcome: to TBN...enjoy.
   / Hi folks! Wildey Farms here, #5
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Case section.
I've fleshed out the profile a little and thanks of the welcomes! Did a little work on the dozer and have figured out that none of the injectors have any return fuel coming from them. Does anyone know if there is a screen or something in the injectors that could be cleaned? I believe they are called pencil injectors.
   / Hi folks! Wildey Farms here, #8
more than likely, you have some junk in the fuel tank that went in to the fuel filter/water separator(hopefully, you have one) clogging it. look into the tank for anything that is not supposed to be there, too..
Thanks radios1. Already did all of that and cleared the lines. That's how I got to pulling part of the return line off of one of the injectors and realizing that there is no bypass fuel coming from the injectors. Like everyone else I go for the low hanging fruit first. Besides, the issue you're talking about would be more of a fuel starving problem which means it probably wouldn't start and run at all. From what I've learned so far if there is a problem with the fuel return the pump will build up too much pressure and kill the engine.
I'm on this forum because I hoping to find that person who has had a similar problem and has some insight. Thanks again for taking the time to send a response.
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2019 Ram 5500 Dump Bed, VIN # 3C7WRNFL2KG599631 (A51572)
2019 Ram 5500 Dump...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
Spartan Pierce Foam Pumper Training Fire Truck (A51692)
Spartan Pierce...
