Hi Flow for Bobcat 773.
   / Hi Flow for Bobcat 773. #1
Hugh OByrne
Albert Lea, Mn
JD4310,JD4400
I have a 2000 Bobcat 773 and it does not have hi-flow. Is it possible to addit and what would it cost?
   / Hi Flow for Bobcat 773. #2
You could perhaps install another dual pump or purchase one pump with an open end and add your low flow pump to it.
or
2.85/1.78 cu in CESSNA DOUBLE PUMP 25586-RAF
Would you have enough HP to operate another pump?
If you need another 20 GPM, at 3000 psi, that would require another 41 HP
Hydraulic System
773G
System Relief @ Quick Couplers 3000 psi
Auxiliary Std Flow N/A
Auxiliary High Flow 27 GPM
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
1999 Talbert T30W-50SA-HRG-1-T1 (A47477)
1999 Talbert...
2023 KOMATSU WA480-8 LOADER (A52705)
2023 KOMATSU...
49" X 74" EXPANDED METAL RAMP GATE (A54756)
49" X 74" EXPANDED...
(2) DOUBLE AXLE FENDERS (A54756)
(2) DOUBLE AXLE...
