Hi Flow for Bobcat 773.
   / Hi Flow for Bobcat 773. #1
Hugh OByrne
Albert Lea, Mn
JD4310,JD4400
I have a 2000 Bobcat 773 and it does not have hi-flow. Is it possible to addit and what would it cost?
   / Hi Flow for Bobcat 773. #2
You could perhaps install another dual pump or purchase one pump with an open end and add your low flow pump to it.
or
2.85/1.78 cu in CESSNA DOUBLE PUMP 25586-RAF
Would you have enough HP to operate another pump?
If you need another 20 GPM, at 3000 psi, that would require another 41 HP
Hydraulic System
773G
System Relief @ Quick Couplers 3000 psi
Auxiliary Std Flow N/A
Auxiliary High Flow 27 GPM
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A55218)
2022 JCB 3TS-8T...
(APPROX 21) UNUSED LANDHONOR PINS (A54757)
(APPROX 21) UNUSED...
Yanmar YM1500 Tractor w/Loader (RUNS) (A50775)
Yanmar YM1500...
