Hi Flow for Bobcat 773.
   / Hi Flow for Bobcat 773. #1
Hugh OByrne
Albert Lea, Mn
JD4310,JD4400
I have a 2000 Bobcat 773 and it does not have hi-flow. Is it possible to addit and what would it cost?
   / Hi Flow for Bobcat 773. #2
You could perhaps install another dual pump or purchase one pump with an open end and add your low flow pump to it.
or
2.85/1.78 cu in CESSNA DOUBLE PUMP 25586-RAF
Would you have enough HP to operate another pump?
If you need another 20 GPM, at 3000 psi, that would require another 41 HP
Hydraulic System
773G
System Relief @ Quick Couplers 3000 psi
Auxiliary Std Flow N/A
Auxiliary High Flow 27 GPM
2011 Cadillac SRX SUV (A50324)
2011 Cadillac SRX...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
