HF tools that suck
/ HF tools that suck #81
..............I bought the larger of the two battery testers they sell. It is the 500 amp one. I thought it was DOA right out of the box (instructions were useless) but when I opened it up and figured out how it worked I knew how to use it and it is a darned good battery tester. ..............Pat
I rest my case. Instruction manual that came with it was a prototype, you refined it! :D
/ HF tools that suck #82
I've had both good and bad luck with DeWalt. They are OK, for light duty use, but seem to wear out fairly quickly on a job. I've also found that there isn't any real consistancy with their tools. Some seem to be worse then others. I still buy them from time to time, but my expectations are always low when I do so. I put them right around Milwakee in quality, reliablity and durability.
The absolute worse product that DeWalt sells are their tips for screw guns. I can't get them to last for more then a few dozen screws. They just strip out and wear away!!! Ritht now I'm using a no name brand called Vulcan that is allot better. I can go most of a day on a tip. Bosch makes good tips too and so did Craftman awhile ago, but not anymore.
My favorites are Makita and Bosch for power tools. I replaced both my 4 1/2 inch grinder and 7 1/4 inch saw that were DeWalt with Makita brands, and the difference is amazing. Smoother, better balance, eaiser to control and just a better fit overall.
Eddie
/ HF tools that suck #83
I bought an expensive DeWalt bench grinder. It turned out to be absolute garbage, made in China. I could have bought a HF unit for half the price, and it would have been better built.
I have not purchased a single DeWalt or B&D item since.
Thanks for mentioning B&D. B&D 4 1/2 inch angle grinder that I have is absolutely exactly like the one DeWalt I have in every respect EXCEPT color and the sticker. Both are Chinese built to price units. The B&D is maybe 10-12 years old and still running while the dead DeWart (Chinese R-L thing) died last week a couple days after a lesser priced DeWart died. It was the week the DeWart Chop saw died. It was like there was a virus going around.
If I had it to do over I would buy Rigid cordless tools instead of having a shop full of DeWart. At least Rigid has good customer service and a terrific guarantee.
Pat
/ HF tools that suck #84
When reading the topic description, i first thought of a vacuum cleaner ;)
Over here in Holland, we dont have HF but there are outlet stores that sometimes sell the same China made stuff that HF sells too..
I bought an Einhell branded cordless drill last year, for 40 Euro. Used it a couple of times, untill the two speed drive started slipping the gears in low, unless i kept force on the shifter knob.
Couple of months ago i bought a Hitachi cordless drill, in a box with a battery flashlight and two batteries, for about 120 Euro. Its 3 times as expensive, but it included a handy flashlight (you'll never run out of batteries on the flashlight because you have the cordless charger allways plugged in) and i still like it after using it as long as i used the Einhell before it failed.
I do have a chinese drill press, and so far i only had to change the crappy V-belt (shoe lash quality) with an industrial quality one from an automotive store...
/ HF tools that suck #85
Renze, I have a HF floor model 16 speed drill press. It is at least 15 and probably closer to 20 years old and going strong on its original two belts. It has an idler pulley for more speeds and so requires two belts.
I have a Delta bench top drill press with continuously variable speed. I have repaired it a couple times and got free parts from Delta since they apparently were aware of the design problem. A week or so ago the 1/2 inch chuck bound up and I paid $47.xx for a replacement. This unit is like new. Had it for 5 years but it has maybe an hour of run time on it at most. It failed during first few minutes of use.
Good performance for the price though since my wife won it as a door prize.
Pat
/ HF tools that suck #86
Pat
I have a whole bunch of Ridgid stuff. We have two sets of their cordless drills (mine and my wife's :cool: ). Never had a lick of trouble with any of it.
/ HF tools that suck #87
No surprise here, but HF tap and die sets are not worth the space they take up on the shelf. I got the holes tapped that I needed with them, but the tap handle broke of just as I was finishing the second hole.
The taps themselves didn't seem to be too bad, but the handle was cheap pot metal.
/ HF tools that suck #88
They have at least two grades of taps/dies. The gold colored/titanium nitrided stuff isn't too bad, the regular metal colored stuff stinks...
Same with their drill bits..I've bought several sets of their gold colored/titanium nitrided bits and they've been pretty good. Bought a set on sale that were just black oxide. Actually bent the 1/4" bit when it stuck in a hole, now how do you bend a bit, not just a little but a lot? No heat treating at all, if it was decent it would have snapped off, or not and just kept going.:)
/ HF tools that suck #89
Oh yea on the bending. But these were meant for drilling cheese I think.Now if they were marketed for wood only that would be fine.
/ HF tools that suck #90
...and ripened cheeses only, no hard cheese.
If the taps and dies are good and only the handle is bad that is just fine as the $ saved buying the taps and dies will surely buy a good handle. I hate the little cast pot metal handles so I don't use them, opting for owning at least a couple GOOD handles.
Pat
/ HF tools that suck #91
They have at least two grades of taps/dies...
That seems to be a pretty good rule of thumb for all their stuff. Their heavy duty widget is about half the price of a regular company's entry level widget; and the HF heavy duty widget will usually compare in longevity, capacity, or performance to the other guy's cheapo widget.
Buy one step up from what you would normally, and you'll have good results.
So where do you get just a good tap handle?
/ HF tools that suck #92
Passed down through the generations I guess. mine is probably third generation.
/ HF tools that suck #93
Snowridge I also have a bunch of ridgid stuff. I have the tablesaw, the portable table saw. the compound sliding mitre saw with the SUV (saw utility vehicle I love that name) Cordless reciprocating saw, cordless 1/2 inch hammer drill, cordless skill saw, cordless caulking gun, cordless flashlight, 7 inch cord type circular saw drill press. k400 drum sewage line cleaner. ridgid air powered finishing nailer.
So far the only problem I have had at all is with the cordless drill. I broke the tip off of one of the arms on the chuck. I called the service center and they told me to bring it in and bring my batteries and charger. I brought all of that in and left it. My drill came back to me with a new chuck. The service person told me that they had some problems with the old style charger and gave me a new version. The new version charged my batteries in half of the time. I also got new batteries. I pay a bit more for their products but the lifetime warranty is really hard to beat.
/ HF tools that suck #95
I bought a HF benchmount chainsaw sharpener the other day. It is pretty cheaply made which is to be expected considering it only cost 28.95. I used it to sharpen the chain for my husquavarna over the weekend. It was not that hard to use and the chain worked a lot better after I sharpened it.
/ HF tools that suck #96
Great thread, good reading. Here are my $0.02
- HF cement mixer. Probably the most expensive thing from HF. Works fine after 4 years of ocasional hard use. The switch gave in this spring
- 14" chop saw. Built two trailers using it plus a lot of other DOM tubing stuff. It eventually died, but I feel I got my $50 worth many times
- chainsaw grinder. Use it for 1 year now, good grinder for the money, recently replaced the wheel with a new one from Baileys- there is a difference
- blue tarp was cheap, but very thin. Died new during Isabella.
- knife blades for sheetrock knife - total junk, more like sheet metal
- borrowed HF engine hoist from a friend, it worked fine, no complaints there, but I think it is used like once a year at max
- car stands
- gloves, sanding sponges, hydraulic jack oil refill, set of fostner bits - all of it ok or good quality.
Every time I stop in HF I buy one of the storehouses like this one. One of the thing that's good to have on hand.
/ HF tools that suck #97
''''chainsaw grinder. Use it for 1 year now, good grinder for the money, recently replaced the wheel with a new one from Baileys- there is a difference
Are you saying there is a difference in the wheels from HF or Baileys? or the sharpeners themselves?
/ HF tools that suck #98
- 14" chop saw. Built two trailers using it plus a lot of other DOM tubing stuff. It eventually died, but I feel I got my $50 worth many times.
That one is quite a surprise. You must have bought one that was made from different specs than the ones made in the last couple of years. I went through 3 before I just said "give me my money back" and they said "too late". I told this story before, but when I sat that junk HF chump saw out out with the trash, I told the trash man that I had the receipt with it and if he wanted I'd give him the receipt and he could go get him a new one. The trash man literally passed on taking it. He said he's seen dozens and dozens of them thrown away and didn't want to waste his time. The junk chop saws from Horrible Freight I had literally had a very, very difficult time cutting a 1/4" bolt in half!! Trying to cut up some 2"X3"X1/4 angle destroyed all 3 chump saws I had from them. I was really peeved after the 3rd one died just like the 2 previous ones and they said all they'd do is give me a replacement. It would cost me far more in gas, not to mention time, to bother replacing those pieces of junk.
Also, as I've mentioned before, I tried to give #3 to my dad. He'd already heard of how terrible they were and gave it back. He didn't even want it for no cost. I wasted my time and burned it up on the first cut when I had it delivered back to me by my dad, unused. I bought myself a quality one between #2 and #3 Horrible Freight chump saw and have made hundreds and hundreds of cuts with it and have had no problem. What's funny about that is the good one I bought is a DeWalt that is made in China. I guess that goes to prove that not everything made in China is junk. It all depends on how the company having it made places their quality requirements.
/ HF tools that suck #99
Eddie
I second the Makita, the beating my 4 1/2" grinder took is hard to believe. Bosch is a great name overseas and I trust it completely - but don't have any yet.
I heard Hitachi is on the level with Makita.
/ HF tools that suck #100
It seems to sharpen better with the Baileys wheel. However it was not my idea, Baileys recommend it for their Chinese grinder too.
I worked in a tool factory for some time and the chainsaw sharpener is a poor excuse for a tool grinder with all the lose joints and the flex of the base and arm - but it is a great improvement over my chainsaw file ability.
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
2015 Chevrolet Silverado Pickup Truck, VIN # 1GCNKPEH7FZ334229 (A65563)
2015 Chevrolet...
Steel Coils (A65640)
