HF tools that suck
/ HF tools that suck #21
I have generally been dissatisfied with most of my HF purchases so I don't bother any more.
Rotary Air Sander- 2 First one quit prepping a horse trailer for repainting. Second one (no, I think it was it the third) worked OK to complete the job.
Hand Sledge - 1 Handle came loose within 20 hits. Replaced by HF (the staff at my local store are pretty good). The handle on the replacement came loose in 4 hits. I rehandled it myself and it has been working for a couple years since.
I have a long list of tools that I have been unhappy with and a short list of tools I have liked.
/ HF tools that suck #22
john_bud said:
Bought a DELL laptop computer for the wife's Chrismas present. It came in a box marked in wee tiny print, "Made in China". Thank's Mr Dell. Makes me think of that salsa commercial, where they string up the guy that brings salsa made in New York, City. If you follow my meaning....
That was probably the box that was made in China....
I've got a bunch of Dells between work and home....they are all made in Malaysia:eek:
I don't know that Dell has ever made personal computers in the US if that was what you were expecting......
/ HF tools that suck #23
Is it just me or do others have trouble actually finding the stuff they are looking for. If I have the part # in hand they can tell me that they have the item but little beyond that. Sorta like hide and seek I guess.
Good junk or bad junk --- it is still fun to just wander and dream, then usually I find something I can use.
/ HF tools that suck #24
Do any of you ever look in the local trading papers for used tools that were US, Japan or European built?
Usually you can find used, older name brand tools for pennies on the dollar that people are trying to unload that'll far outlast new HF tools.
/ HF tools that suck #25
Ahh YES!!! I too have been disappointed by HF... By the shear joy and excitement of breaking in (pun intended) my new double flaring tool...:rolleyes: ... First use on a (what else) Brake line...:D :D
I have always been leary of buying anything electrical from them so that was a non issue..Thankfully... grinding disc's & sand paper is a safe bet...;)
I did get my beam trolley from them for my PHD, shown in picture, But the Airhose retracting reel (hard to see in pic) came from Northern...No complaints yet...
/ HF tools that suck #26
Nope it is not just you. I was in Saturday and was looking to pick up a set of 3/8 sockets and ratchet to leave in the wife's car just in case. They had 30 but couldn't find them. They weren't hanging on the socket aisle with the 1/4 and 1/2 sets just like it...go figure. Finally as I was leaving with my other purchases a guy ran out in the parking lot and hollered they found them:)
/ HF tools that suck #27
I wonder if they do that on purpose. It's like an Easter egg hunt for grown men.
/ HF tools that suck #28
Hahaha, that's funny.
OK, here's my list. I bought a bunch of tools to use at camp in case I needed them. I didn't expect much performance from them but got them anyway.
Using your rating system...
3lb hand sledge hammer-9 or 10
Chisel set- 2
Small 10" band saw-4 (8 after I fixed it)
Portable Hand held band saw-1 (7 after I fixed it)
Portable dust collector-3 (6 after I fixed it)
$16 battery operated drill-8 (pretty good especially for the price)
$16 4-1/2" Angle grinder-8
12" compound miter saw-8 pretty good
portable rotating laser level-3
Sae and Metric open end wrenches-8
Sae and Metric deep impact sockets-9 very good
6" dial caliper-10 measures perfect.
/ HF tools that suck #29
beersngars said:
OK. Good idea.
Junk items are;
Hole saw set... rating-1 Ok if drilling lard
Air grease gun...rating-3 just lame
Puller set...rating-2 lasted 1 time per size
These are all that come to mind.
Sorry I missed this post. These are just the tools I've been needing. The last time I drilled lard the pig died. Guess I needed a sharper saw.
/ HF tools that suck #30
Hmmm, monday may be a bad day.. After hearing the name "harbor frieght" on this site so much, thursday, I placed an order for lot's of items..
1 924-6VGA 6.99
12 PC. FILE & RASP SET
1 45732-1VGA 4.99
32 PC. METRIC HYDRAULIC GREASE FITTINGS
1 92226-1VGA 19.99
WALL MOUNTED STORAGE BIN SYSTEM
1 93258-4VGA 12.99
1.5 AMP ONBOARD BATTERY CHARGER
1 96777-2VGA 9.99
Pack of 4 20 Ft. Sanding Paper Rolls
1 94030-4VGA 5.99
DUMMY SECURITY CAMERA
1 91851-0VGA 49.99
Weatherproof Color Security Camera with Night Vision
/ HF tools that suck #31
4x8 HD Trailer "kit" - 6 or 7
"matching" steel side kit - 2 or 3
After several weeks of tinkering, I finally have my HF trailer together. I was thinking it would take one evening or two to assemble - HAH! This is the heavy duty 4x8 one rated for 1700lbs. It was mostly OK, but they included 2 right side rear frame rails in the box and NO left side rear frame rails. HF Customer service said they could ship me one but it would probably take several weeks. Local store broke open another kit and exchanged rails.
The axle had a weld burr right where the wheel seal should run. Good thing I felt it, or the seal would be toast. Hopefully my file/sand job is good enough that the seal won't leak too much.
The bracket for the tongue-to-frame pin where the trailer will tilt was welded crooked so the pin had to be hammered in - a little rat-tailing fixed that.
The wiring harness supplied was 10" too short to make it to the far taillight.
The steel side kit was a disaster - it is intended to fit flat on the trailer frame, with the plywood flooring over/inside it's edge lip - except the frame has bolt heads protruding! No problem, a hole saw made cutouts for the bolt heads. The tailgate is intended to be removable, except that's kinda hard to do if it fits UNDER the plywood - so the floor had to be notched to fit the tailgate. Once the floor is notched out, the rear frame crossmember no longer supports the floor - so weld a 1-1/2x1-1/2 angle iron to the crossmember, grind, sand, attempt to paint to match. The instructions are quite clear that the bolts provided are to go through the floor (3/4" ply), then through the side kit (maybe 18 ga sheet), then through the trailer frame (maybe 1/8") - the bolts included are *16mm* long!! The sides are made in two halves, piano-hinged together, and the edges for the hinges to mount to protrude into the inside of the trailer, so the plywood again had to be notched to fit (there goes the full 48" width of the trailer). the pre-drilled holes to attach the front to the sides were off by about 1/2" so now there's fender washers inside to cover the big elongated holes. Now after one week outside, it's got rust spots all over where the factory (lead?) paint is missing/chipped/scraped. There is no provision to close the corrugated ribs in the front/sides against rain intrusion - I'll have to cut/form some blocks to fit in and then caulk. The parts list shows a custom-fitted, bungee-edged tarp, the photos on the box show the tarp, the instructions detail how to install the tarp - no tarp included. All HF customer service will say is "it's not supposed to include the tarp, that's $7.99 extra".
- Jay
- Jay
/ HF tools that suck #33
Sure is. sounds like more work than making my own.
/ HF tools that suck #34
I saw a remote control airplain that I figured my dad might enjoy. It was garbage.
Ah, too bad.
I have been eying that little airplane with the idea of putting an infra-red camera in it with a link to a monitor.
Imagine what one of these would do for your success rate in hunting season. Half an hour flying the little airplane and you could have every deer for miles marked on your map...
/ HF tools that suck #36
Wow glad your 'privates' and non privates are fine. I was wondering what part broke? so I can beware of that. I have a set of these, and didn't quite trust them , even if they were the more expensive ones. But the set I have has done a few strut changes, It will be interesting to see if others have had the same experiences thanks
/ HF tools that suck #37
In keeping with the "suck" category, here's one for ya
1/2" ratchet extentions -0
Broke one putting the "mustard" to a 5/8" bolt and snapped the end off, putting me to the concrete with major hip and knee pain for 5 days. Have since gotten rid of all those in favor of name brand.
/ HF tools that suck #38
Omg. I wonder how many injury's or stresses these tools do. I'm sure there are no statistics.
/ HF tools that suck #39
Ratchet Bar Clamps = 1
My 9 year old son was saving his money for some clamps for woodworking. He had purchased several Bessy clamps in the past, but those are expensive. He saw the HF ad for a set of clamps for 75% off or something along those lines. Figuring he could buy 4 clamps for less than one Bessy clamp, he wanted to try the HF set. So he buys them with his own money. He proudly showed them off to Grandma and Grandpa telling them what a great deal they were. First time using them, the large clamp splits in half. Mind you, this is caused by the hand clamping pressure of a 9 year old boy. He stood there holding it, one piece in each hand, tears streaming down his face. We exchanged them for a new set, but they are all but worthless since he is afraid to use them or else they might break too.
Not all things made in China are junk, but to this 9 year old they are now. He looks at the label of everything he buys to see where it is made. He is saving his money for more of the Bessy clamps, made in Germany.
/ HF tools that suck #40
I bought a 'cheap' set of the strap wrenches, and assumed id use them for light duty. they couldn't handle that. so they went in the dump.They are something that its hard to use the parts for to make something new.So to the dump they went.
2004 International 4400 Single Axle Dump (A62613)
2004 International...
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
Club Car Emergency Cart (A64557)
Club Car Emergency...
John Deere 490E Excavator (A62679)
John Deere 490E...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
