Rear Blade HF Quick hitch too narrow
   / HF Quick hitch too narrow #11
Looks like you can cut an inch or two off the square tube on each side and reweld the cap, pin and gusset back on. Sucks to have to do that to a new implement though.
Ian
That's of course an option but much more work than what I suggested.
from tube to center of pin is 1 5/8in
   / HF Quick hitch too narrow #13
OK, I think that would probably be too close then, turning the pins to the inside probably isn't going to work.
   / HF Quick hitch too narrow #14
Then don't forget the 1 1/8 sleeves that are supposed to be installed on the attachment pins in all these measurements.
   / HF Quick hitch too narrow #15
I didn't explain it well enough but that's why I also suggested welding some 1/4" by 1" flat on edge to the outside, above and below the nut. You would go the entire length of the plate that is welded to the square tubing and has the pin mounted in it. In other words, you would basically form that into a channel iron with just enough room to turn the nut. I think that would be just as strong as original if not even a little stronger because it would actually reinforce all the way out to the pin. Again, that is if there is enough room between the pin and the square tubing to allow this.
Yeah, I think I see what you're describing. Rather then two 1/4"x 1" flats, I'd consider a couple short lengths of "C" channel welded all around. He'd have to burn a hole large enough for the nuts though.
However, I still think scrivy69 needs to wait until the QH comes in. It might fit great or he might be best served by returning the rear blade. If his measurements are correct (and I've no doubt they are), that blade seems to be a bit large for a Category 1 (3PH) hook up.
   / HF Quick hitch too narrow #16
I'm with Roy; wait for your QH.
FYI: I bought a blade from TSC that should have been CAT1, but the welds were sloppy and the yoke was wide. If that's your case, take the blade back as not being compliant with the standard.
It was too late for me, and I eneded up cutting and rewelding the yoke to fit. Not something I really enjoy doing.
   / HF Quick hitch too narrow #17
It stinks to have to chop up and weld on a new piece of equipment but I had to do the very same thing with a 72" united box blade to make it fit my HF QH. The brackets for the lower pins were not welded on straight and it would not fit the QH. After a few hours of cutting, grinding and welding on my new shiney red BB I had it fixed.
I don't know why manufactures don't do a better job making their stuff to fit a QH.
   / HF Quick hitch too narrow #18
Hello everyone i just bought a new rear blade ( it seem a little wider than category 1) HF quick hitch on order right will probably be too narrow, Just thinking has anyone ever switched the pins from outside to the inside, would this work? and with this blade
Standard QH is 27.5 inside to pins and 29.5 - 30" outside. Your mount flanges are smack dap in middle of the QH hooks. Your going to need that special 31.5" that was mentioned in earlier post or modify the pin mounts, depends on if wider QH will work on your other attachments.
   / HF Quick hitch too narrow #19
You could add a lot of strength in the lower pin area by making it a captured pin-a pin with supports on both ends. If the QH will fit between the square box and the pin then just a small piece of 1/4" with a 7/8" hole lined up with the existing hole, weld it on about 2" inside the other and get a pin that fits through both. You have a stronger pin area, and have solved your location problem.
I would definitely do what was necessary to make it fit--having a QH is just too handy.
Mike
   / HF Quick hitch too narrow #20
As MJP (Mike) said, I'd look at capturing the pins too.
Just a little bit of cut and weld will fab the blade to fit the QH, and it will be worth every bit of effort.
I'd leave it so the pins could be put back in their original spot just in case you have a need or want to sell it (although prolly worth more to have it QH compatible).
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2016 Husqarvana YTA22V46 46in Riding Mower (A56859)
2016 Husqarvana...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
