HF Metal Detector any good?
   / HF Metal Detector any good? #1
texasjohn
Super Member
Central Texas, Jarrell
Kubota Grand L5030HSTC
Harbor Freight has a metal detector on sale for $20.
I'm wondering if this is worth having in case somebody loses a ring in the hay, or if I were to drop a tractor pin into tall grass... or?
Sometimes, I use old lumber and this might locate hidden nails and save a saw blade?
I'm not planning to do treasure hunting with it.
Anybody have any experience with this model, 43150?
   / HF Metal Detector any good? #2
I have one. I only use it for steel and it's mostly marginal. I would not expect to find nails. I think a 2" x 2" piece of flat bar may be it's limit. Sorry I don't know about other metals.
OK... gonna strike that from my want list... thanks!!!
If it won't find nails in a wood plank, then it's use to me nears zero.
   / HF Metal Detector any good? #4
Yeh, that's just my take on it but I think you're moving in the right direction.
   / HF Metal Detector any good? #5
I had the same results, $20 wasted.
Done deal..... no deal! Thanks for saving me $20:D
   / HF Metal Detector any good? #7
Actually, I could UPS you Mine! :D
   / HF Metal Detector any good? #8
John,
You really knew the answer to this before you even posted the question didn't you:D
Well, Kenny, I gotta tell you I was suspicious... but you never know.. and I thought I'd call on the combined TBN wisdom to see if I was missing out on a really good deal. You know, some of the HF stuff actually works!:D
   / HF Metal Detector any good? #10
I think the main difference between the "cheap" and "expensive" detectors are their ability to discriminate between different metals. Other than that - the detectors are pretty simple in construction. If all you are trying to do is find metal (like a property marker) even a cheap one should work. However - if you are trying to do beach work I would look for a much more expensive unit (unless you enjoy digging up bottle caps).
For example - I bought an xmas leftover metal detector at TSC about a year and a half ago for something like $15. It was good enough to find dog tags in a pile of leaves, locate property markers, and find a conduit run that I buried in a wall five years earlier.
Some elaboration on the conduit - while redoing a room on the first floor - I decided to take advantage of an open wall by running a couple pieces of 3/4" EMT from the crawl space up to the second floor. About five (or six) years later - when it was time to run the electrical and CATV/telephone lines - I used the metal detector to locate the conduit within the second floor wall. It found the conduit in about two seconds.
Anyways - my two cents. Your mileage may vary.
Joe
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Pallet Forks for Tractor (A51573)
Pallet Forks for...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
1994 HONDA 300 FOURTRAX ATV (A51247)
1994 HONDA 300...
2016 CATERPILLAR 277D SKID STEER (A51246)
2016 CATERPILLAR...
2015 GMC Acadia SUV (A51694)
2015 GMC Acadia...
