HF Metal Detector any good?
   / HF Metal Detector any good? #1
texasjohn
Super Member
Central Texas, Jarrell
Kubota Grand L5030HSTC
Harbor Freight has a metal detector on sale for $20.
I'm wondering if this is worth having in case somebody loses a ring in the hay, or if I were to drop a tractor pin into tall grass... or?
Sometimes, I use old lumber and this might locate hidden nails and save a saw blade?
I'm not planning to do treasure hunting with it.
Anybody have any experience with this model, 43150?
   / HF Metal Detector any good? #2
I have one. I only use it for steel and it's mostly marginal. I would not expect to find nails. I think a 2" x 2" piece of flat bar may be it's limit. Sorry I don't know about other metals.
OK... gonna strike that from my want list... thanks!!!
If it won't find nails in a wood plank, then it's use to me nears zero.
   / HF Metal Detector any good? #4
Yeh, that's just my take on it but I think you're moving in the right direction.
   / HF Metal Detector any good? #5
I had the same results, $20 wasted.
Done deal..... no deal! Thanks for saving me $20:D
   / HF Metal Detector any good? #7
Actually, I could UPS you Mine! :D
   / HF Metal Detector any good? #8
John,
You really knew the answer to this before you even posted the question didn't you:D
Well, Kenny, I gotta tell you I was suspicious... but you never know.. and I thought I'd call on the combined TBN wisdom to see if I was missing out on a really good deal. You know, some of the HF stuff actually works!:D
   / HF Metal Detector any good? #10
I think the main difference between the "cheap" and "expensive" detectors are their ability to discriminate between different metals. Other than that - the detectors are pretty simple in construction. If all you are trying to do is find metal (like a property marker) even a cheap one should work. However - if you are trying to do beach work I would look for a much more expensive unit (unless you enjoy digging up bottle caps).
For example - I bought an xmas leftover metal detector at TSC about a year and a half ago for something like $15. It was good enough to find dog tags in a pile of leaves, locate property markers, and find a conduit run that I buried in a wall five years earlier.
Some elaboration on the conduit - while redoing a room on the first floor - I decided to take advantage of an open wall by running a couple pieces of 3/4" EMT from the crawl space up to the second floor. About five (or six) years later - when it was time to run the electrical and CATV/telephone lines - I used the metal detector to locate the conduit within the second floor wall. It found the conduit in about two seconds.
Anyways - my two cents. Your mileage may vary.
Joe
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
New/Unused Quick Attach Rock Breaker (A51573)
New/Unused Quick...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
