Hey John Miller or anyone else
   / Hey John Miller or anyone else #11
Gannon does make various qualitiesm the 4X4 line is tough. They are about the only ones you see on industrial tractors. The John Deere 210's and Case Industrial loaders use 96" Gannon 4X4's, if these tractors that all have 4WD can't destroy them, chances are your not going to. Its easy to tell the heavy duty Gannon's today, they come in black
John,
Is this box blade made by the same people who made the 513 rotary cutter.
I don't know about not tearing things up,I could mess up an anvil with a rubber mallet.LOL!!!!!!
   / Hey John Miller or anyone else #14
I have had good luck with Gannon box blades by Woods. The model I have is a 6' 4272HD High Back (picture attaced) for a L4310. Very heavy construction. Top-N-Tilt controls are a must if you will be doing a lot of box blade work. For occasional work, the manual 3PH is fine. Be sure to get one that is wider than the tires.
   / Hey John Miller or anyone else #15
I have a Woods BB600HS 6' with hydraulic scarifier for $865.00, it is new. If you're interested drop me a line.
   / Hey John Miller or anyone else #17
I have the Woods and it has gone over rocks, stumps, made about everything and generally been sorely abused and it is none the worse for wear. No bent parts or anything. I'd recommend it. I don't think there's anyway you could tear it up with a compact tractor.
   / Hey John Miller or anyone else #18
Scruffy,
I have a Gannon Landscraper box blade 66" wide and ~900 pounds. It is made with 1/2 inch steel for the end plates (and about everything else!) I don't even know how it could be hurt, much less "bent every which way to Sunday", but I do know that I won't be lending it out to your neighbor!!!
Back to the main question:
Buy as much weight as you can afford and your tractor can pull. Box blades, and most ground engaging equipment, work better and better as they weight more and more. The professional duty models that Gannon and Gearmore and others make have a loyal following on this board, so I assume they are all good. But expensive.
John Bud
   / Hey John Miller or anyone else #19
Mulkey, thats the one. You have a great boxscraper there. Gannon/Woods also manufactuers the ones made for Kubota when you buy it as a Kubota part. Rat
P.S. where about in Placer county are you?
   / Hey John Miller or anyone else #20
Rat, I'm interested in your hydraulic Gearmore. They dont seem to be well known here in the East. Could you tell us which size you have, how much you paid, and where you got it--from a dealer or direct from Gearmore? I'd like to compare the prices against the ones I am getting here for hydraulic Gannons and Landprides.
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
Hose Reel (A53424)
Hose Reel (A53424)
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
2020 PRAT TL (A55758)
