Heres your 2720 pictures!!!
   / Heres your 2720 pictures!!! #1
newt92
Secor Illinois
John Deere 2520 and 2305
Here you go fans!!
Here are the restyled 3pt arms
Right side of engine
Left side of engine
Another 2720 along with a 3720
   / Heres your 2720 pictures!!! #2
I think I need a cigarette after looking at the 2720 facing the 3720!
   / Heres your 2720 pictures!!! #3
OH man, now that is funny:D
   / Heres your 2720 pictures!!! #4
Thanks for the images, I have been considering the 2720. I heard of a redesign for the seat, any additional info?
What do all you experienced tractor guys think about the bump in HP and torque? do you think it will resolve the limitation of mostly mowing in low issue?
Thanks
   / Heres your 2720 pictures!!! #5
I was critical of JD for developing the 2720 with only a 2 range Hydro. I may have to eat my words...
I noted on the JD website that the 2720 has the same 100cu.in. engine that is used in the 3320!! (Unless it's an error...)
If that's the case --- you could likely mow all day long in HIGH range with a 4-5' mower!!!
Now... the option of a 3pt. shoulder harness and seat belt might be required to keep your butt locked into the seat at those speeds but you probably won't run out of black smoke from the engine!
AKfish
   / Heres your 2720 pictures!!! #6
Related inquiry...
I wonder if JD will use the newly designed draft arms on the latest crop of 2520's?
How about retrofitting the current owner's of 2520's with the newly designed 3pt. arms?
I know a couple of 2520 owner's that would be just "tickled pink" if they could divest themselves of those "chafing and rubbing" nuisances!
AKfish
   / Heres your 2720 pictures!!! #7
Those 3 pt arms worry me... You'd need an awful strong bungee to hold them together and keep'em from swaying when you pick up a load. I'm not sure I could stretch one out enough to hold...
   / Heres your 2720 pictures!!! #8
I also like the beefed up alternator. I could really run some bells and whistles w/ that one. Next accessory: A JD Dash mount CD/SAT Radio player w/ "in-Rops" hi-amp speakers......to spread the goodness of Bluegrass to my deprived Colorado-born neighbors.
v/r mark
AKfish said:
Related inquiry...
AKfish
There was I think 4 new 2520s next to the 2720, and the 2520s had the old style arms on. I would guess Deere wont change the 2520s until maybe the next model year.
   / Heres your 2720 pictures!!! #10
Does the new 2720 feature the new design draft arms?
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
HARDEE RD72M LOT NUMBER 154 (A53084)
HARDEE RD72M LOT...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A52576)
2012 VOLVO VNL...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
LOT NUMBER 251 (A53084)
LOT NUMBER 251...
