Here to learn
/ Here to learn #1
Butch51
oxford
mahindrqa EMax 22
I bought a Mahindra Emax22 a little over 2 years ago. I joined to see what others are having problems with so that I might be able to understand the troubles I am having with mine. Even the dealer can't figure out why I'm blowing the 10 amp fuse all the time. Has changed the fuel solenoid twice but the tractor will only last about 6 hours after that and the fuse blows when you turn the key to the start position.
/ Here to learn #4
Welcome to TBN. Do not know your tractor but if the fuse is lasting about the same amount of time is it when it has been running all those hours? Have you tested to see what the amp draw is on it? Are you sure nothing has been added to the circuit such as dealer or your installing a light? Look for a worn or pinched wire. Also if you can you may wish to see about installing a circuit breaker for they can take a short over load where a regular fuse will not.
/ Here to learn #5
Butch51
Welcome to TBN this is a good place to get help or advice on most makes and models of tractors. The best help will come from pictures of the problem.
/ Here to learn #6
Welcome to TBN Butch51...enjoy.
/ Here to learn #7
:welcome:
Welcome to the forum!
It looks like you already have a few replies over in the Mahindra section. Hopefully, one will be the answer :)
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2013 Ram 5500 Bucket Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
2005 John Deere 7420 (A60462)
2005 John Deere...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
INOP/NON-RUNNING 1997 GMC T7500 Truck, VIN # 1GDJ7C1P2VJ505340 (A61165)
INOP/NON-RUNNING...
