Seeders Herd Seeders? M96? 160? 5.5?
   / Herd Seeders? M96? 160? 5.5?
BeeFarmer wrote: <font color="red"> Bob I really ejoy mine! I've used it with lime, fert, and seed and so far so good for the last 3 years or so. </font>
NY_ wrote : <font color="green"> I have a M96 and it works fine for me. </font>
Murph wrote : <font color="blue"> I have the M96 and like it a lot. It is a lightweight/durable unit and have had no trouble with it. </font>
OK so I have a question for all 3 of you. Can any of you see to the bottom of the hopper while you are in the tractor seat? I've used mine twice, I admit to liking it, it seems to throw farther to the right than to the left, but that may just be my perception as I did not measure it (Murph mentioned this also). But it does have one major flaw. . . I can't see the bottom so I can't tell when I am going to run out!
My plan is to do a few modifications to the spreader.
#1, I want to mount a mirror of some sort to the back rim of the spreader so when I turn around I can see into the bottom of the the spreader.
#2, I want to make a stand that is welded to the lower assembly so that it will rest on the ground upright instead of having to either lay it down or turn it upside down and stand it on its rim.
#3, it needs some sort of a grab handle near the top to make mounting easier and to make it easier to move around. Although if the integrated stand from modification #2 works it might eliminate most of the need for the grab handle?
   / Herd Seeders? M96? 160? 5.5? #22
Bob,
I made a plywood dolly and the M96 sits on the dolly with the 3 pt down. I put a block of wood under the rear of the spreader so the M96 is upright position. I just pull the BX up to the dolly, connect the 3 pt and away I go. I can not see into the bottom either, but after spreading fertilizer a few times I kinda of know when I am getting low. If you need more pictures on the dolly let me know.
Dolly
web page
My modification to the M96
web page
   / Herd Seeders? M96? 160? 5.5? #23
</font><font color="blue" class="small">( I can't see the bottom so I can't tell when I am going to run out!)</font>
Well your right about that, but I think that would be a problem with them all. I just stand up a bit and look as I drive. You know when it gets to the point that you can't see much then it is about time to refill. As far as spreading heavy to one side pretty much any single spinner will do that. That is the nature of a single spinner.
murph
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
Year: 1996 Make: Freightliner Model: FLD112SD Vehicle Type: Truck Mileage: Plate: Body Type: (A55852)
Year: 1996 Make...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
J and L Cargo Express Shadowmaster Enclosed Trailer (A55315)
J and L Cargo...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
