Henro - here's some 3ph pics.
/ Henro - here's some 3ph pics. #1
MBman
Atlanta
Henro - here\'s some 3ph pics.
Here's some rear 3 point pics. I took these yesterday afternoon. I should have been hogging and decided not have the fel on so I could clean up some tighter areas.
It was working as planed until I peed off the yellow jackets somehow. I beg to differ on the top speed of this thing. I believe it reached sixty two mph uphill in this configuration.
After some medical teatment for the 5 good stings and my mood altered for the afternoon, I took some pics.
Rich
Re: Henro - here\'s some 3ph pics.
another
When I bought the tractor 2 months ago I purchase and had them deliver with it another adjustable lift link. So if you study the pic you may be able to see my mods.
!. Both adjustable lift links.
2. b sway bar instead of bx sway chains.
3. heavy duty cat. 1 upper link shortened 3/4 in. off each end.
4. turned the bush hog lift pins inward. (slightly easier to attach)
5. heavy duty lynch pins (only in sizes I could find. They are black in color)
6.Lynch pins installed in the clevis pins. (I drilled the top lift arm clevis pins to replace the cotter pins with lynch pins for faster removal of the 3 point set up)
differt angle
/ Henro - here's some 3ph pics. #5
I've been thinking about switching the sway chains on mine for B sway bars for about 2 years. Just broke my 4th chain. Did you have to make any mods to the bars for them to fit?
/ Henro - here's some 3ph pics. #6
There are a lot of posts on the stabilizer bar mods on the site if you do a search, although I don't have much luck with searching the site. Here are a couple of pics that maybe you can use, I think you'll find that it is one of the best mods you can make. The first one shows the end of the tube that needs to be slotted to fit over the rear attach point.
/ Henro - here's some 3ph pics. #8
MBman,
Thanks for taking the time to post those photos!
I am still up in the air about buying a rotary cutter for the BX since I already have one for the B2910....but the bx just feels so much more stable on cross slopes, I think I will buy one.
I see KK offers a 40 inch rotary cutter...maybe that would be the ticket for me...seeing I have a larger one for the larger tractor. Heck, I only have 2 acres that it would be used on. The rest is grass or short weeds... /forums/images/graemlins/blush.gif
Great photos!
/ Henro - here's some 3ph pics. #9
Very Very cool. Thank you very much. I saved the pics so I have something to look at when installing, although it certainly doesn't seem to tough. Super info, thanks again.
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
John Deere Silage Wagon (A65640)
John Deere Silage...
2022 EZ-GO ELITE...
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
