help
corvettejake
uniontown pa
1977 yanmar
i have a 1977 Yanmar tractor with a Brantley hoe attchment every time I move the hoe the steering goes sharpley to the left and you can not steer it while running any answers. thanks jake
Could you post pics of how its plumbed in that would help a bunch to see what we are talking about? I am thinking it must be plumbed into the p/s pressure or return instead of the pump output to the 3 pt.
Good chance you do not have enough weight on the front and the tractor is lifting up enough that you loose steering. Put some weight up front and see if it changes.
I have that problem when plowing snow with the back blade, and have over 200 pounds of weight on the front of the tractor. Use the heck out of the break petals. What model Yanmar? And how big of a plow?
New Idea 201 Manure Spreader (A66408)
New Idea 201...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
2019 CIMC 40ft. 36 Ton T/A Container Trailer (A64556)
2019 CIMC 40ft. 36...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2010 Transcraft 35ft. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Transcraft...
