Help!!!!
/ Help!!!!
Steve,
I checked under the hood and unable to locate 30 amp fuse. Also looked in the B2150 operator's manual and only see two 15 amp fuses and the fuseable link listed.
However, there is an "engine stop solenoid" and an "engine stop timer relay" showing in the operator's manual wiring diagram.
Do you have a B2150??
/ Help!!!! #22
Don't know if this will help, but it may simplify. Strip off everything you can (deck, bagger, hood, all the covers. This may help you locate the fuse (or... perhaps smoked?/cut harness)
/ Help!!!!
Eureka! Problem solved. The 200 amp fuse link was in fact burnt at the base of the loop. Also, there was a wire from the clutch safety switch rubbed bare. It is the switch that the clutch activates when the clutch pedal is depressed. The steering arm has a nut with a cotter (sp?) pin. The wire had gotten hung up on the pin and apparently shorted out. I have no idea why the fuseable link burnt when I tangled with the rope. But whatever the case, the tractor is now alive and well again.
THANKS FOR ALL THE "HELP"!
/ Help!!!! #24
Hey qbc3, glad you got it fixed. I'm sure it was the rope slappin around where it shouldn't have been.
Next time you wanna go ropin, getta horse /forums/images/graemlins/wink.gif
Just kiddin, I've run over stuff I shouldn't have too /forums/images/graemlins/shocked.gif
/ Help!!!! #25
good job! and all without the cost of a service call! /forums/images/graemlins/laugh.gif seems like hot dogs and beer for all the guys /forums/images/graemlins/smirk.gif /forums/images/graemlins/grin.gif
/ Help!!!!
Billy: No more ropin for me!! Next time I need to cut rope, I'll use a knife!
Frank: Love this forum. And thank all of those who chipped in their advice.
Rogue: I almost felt you were lookin over my shoulder as I worked on the tractor.
Thanks to all!! :>)
/ Help!!!! #27
I was going batty that night waiting to hear what it was. Glad it worked out ok.
/ Help!!!! #28
</font><font color="blue" class="small">( Billy: No more ropin for me!! Next time I need to cut rope, I'll use a knife!
)</font>
Last time I used a knife to get a rope untangled from a snow blower it was a trip to the ER for stitches! /forums/images/graemlins/blush.gif The Nurse called it "dumb after dark".
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2011 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2011 Chevrolet...
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
2014 Dodge Charger Sedan (A61574)
2014 Dodge Charger...
2015 Ford F-450 Crew Cab Dump Truck (A61573)
2015 Ford F-450...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
