help
dwaine60
massey ferguson 135
Can someone help me with m mf 135 i'm gooing insane!I had a power steering hose blow out I had it repaired now the power steering fluid is coming out of the veat as fast as I can put it in!Any thoughts!:mad::mad:
Maybe theres air entrained. Fill to correct level and let it sit. check it tomorrow.
larry
You wrote "you had it repaired"? Did you remove and re-install the hose?
It's possible there is air in there. Did you add any fluid? Did you lose any fluid when the hose was removed?
First, if the repair shop did the removal and re-installation, contact them with your problem...because it might be their problem.
If you did the removal and installation, remove the hose and look for an obstruction of any sort (shine a light through it). That fluid is coming out of the vent because the system is either overfilled or the fluid cannot return to the system (meaning some kind of restriction...which could even be too small an inside hose or fitting diameter).
If you have the original hose (I'm assuming you had a replacement made), compare it to the hose you had made.
If the replacement hose is correct, re-install it and make sure it's routed so there are no kinks or anything else that could obstruct the flow.
/ help
Hey thanks for the reply it seams there is a seal blown inside the steering system causing the fluid to enter where it shouldn't I hope this fixes the problem if not bake to the drawing board.Thanks for your help
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
2013 Lincoln MKZ Sedan (A61569)
2013 Lincoln MKZ...
UNUSED KUBOTA BRUSH GUARD (A62130)
UNUSED KUBOTA...
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
2025 Kivel Quick Hitch Skid Steer Attachment (A61567)
2025 Kivel Quick...
2015 Ford F-350 4x4 Ext. Cab Service Truck (A61568)
2015 Ford F-350...
