help
   / help #11
Yup. Check the dipsticks and see which was drained for sure. Engine oil dipstick is under the hood and and twists out and the transmission dipstick is at the rear of the tractor(and a pain to pull out...is not threaded like the engine dipstick).
Wipe the dipsticks off and reinsert to check the level as residual oil may be stuck on the dipstick when you first pull them out and may appear full.
   / help
Hey Cubuser,The drain plug that my son drained seems to be on the moter itself.It was red.I went ahead and changed the oil and refilled it.The mower still will not move.Must be doing something wrong. Thanks anyway.
   / help #13
Is the tranny lockout lever pulled out? Located at rear of tractor on lower right of back panel.
   / help #14
YOu off your medication today or something?
Whether or not it was Godzilla that did it, the damage is done. The guy needs help. So let's help him out.
So, with that said I'm sorry to say I'm not knowledgeable enough to help you out with this situation. But someone will.
Just a curiosity question.
What's the federal crime/ where was the harm in it?:confused:
Boy some can find fault with anything .:eek:
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2022 Ram 2500 (A55973)
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
White Metal Roof Panels (A55758)
White Metal Roof...
