? help xj2025 no position control brush hogging
   / ? help xj2025 no position control brush hogging #1
cvcman
syracuse ny
john deere
Ok my ne xj2025h will be here next week with a 4ft rotary mower...It appears there is NO position control...what do you guys do brush hogging ???
   / ? help xj2025 no position control brush hogging #2
Some install check chains to maintain a specific height.
   / ? help xj2025 no position control brush hogging #3
Keep an eye on the "knuckle link" at the toplink to bushog connection. As your liftarms slowly leak down the aspect will change. Adjust as needed.
   / ? help xj2025 no position control brush hogging #4
I don't have a problem arms leaking down. I adjust height as I go along at the beginning and once I find the right height, I leave it alone. I use a chain in place of the top link on the 3pt when brush hogging. I also have a 4ft and wished I went with a 4ft.
A chain in place of the top link ?? I though the side arms determined the height not the top link ?? And ive heard that with a chain if you hit something the cutter could come up and crush you ???
And what do you mean " I have a 4ft and wish I went with a 4ft ????
   / ? help xj2025 no position control brush hogging #6
Can't say I've ever heard the crush story. Not worried about that in the least. I don't see how that's even possible.
Chain for the top link gives the brush hog some room to "ride" the hills and bumps. Lets the tail have a little room to move up and down. The more slack, the more it can move. It's been used by farmers for many many years.
Wished I bought a 5ft because its wider and the tractor could still power it.
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2016 Cat TL1055D Telehandler (A56435)
2016 Cat TL1055D...
Kubota LX2620 (A53317)
