? help xj2025 no position control brush hogging
   / ? help xj2025 no position control brush hogging #1
cvcman
syracuse ny
john deere
Ok my ne xj2025h will be here next week with a 4ft rotary mower...It appears there is NO position control...what do you guys do brush hogging ???
   / ? help xj2025 no position control brush hogging #2
Some install check chains to maintain a specific height.
   / ? help xj2025 no position control brush hogging #3
Keep an eye on the "knuckle link" at the toplink to bushog connection. As your liftarms slowly leak down the aspect will change. Adjust as needed.
   / ? help xj2025 no position control brush hogging #4
I don't have a problem arms leaking down. I adjust height as I go along at the beginning and once I find the right height, I leave it alone. I use a chain in place of the top link on the 3pt when brush hogging. I also have a 4ft and wished I went with a 4ft.
A chain in place of the top link ?? I though the side arms determined the height not the top link ?? And ive heard that with a chain if you hit something the cutter could come up and crush you ???
And what do you mean " I have a 4ft and wish I went with a 4ft ????
   / ? help xj2025 no position control brush hogging #6
Can't say I've ever heard the crush story. Not worried about that in the least. I don't see how that's even possible.
Chain for the top link gives the brush hog some room to "ride" the hills and bumps. Lets the tail have a little room to move up and down. The more slack, the more it can move. It's been used by farmers for many many years.
Wished I bought a 5ft because its wider and the tractor could still power it.
UNUSED CFG INDUATRIAL SSECAG-Y AUGER BITS (A51244)
UNUSED CFG...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52128)
Kubota BX2680...
(8) TRACTOR WEIGHTS (A51244)
(8) TRACTOR...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRA (A51243)
2012 MACK PINNACLE...
