Help!!! Workmaster 55 Won't Start
/ Help!!! Workmaster 55 Won't Start #1
SouthernINguy
Georgetown, IN
New Holland Workmaster 55
Hello All. New guy here. I have a 2010 Workmaster 55 with around 300 hours on it and I am having trouble getting it to start. It has always started up just fine until about 2 weeks ago when I went to use it to do some tilling and it wouldn't start. Turns over just fine but won't fire. A few days later I went back and it started just fine and started right up again yesterday. I went out today to do some driveway grading and again it won't start. I believe that normally when you first turn the key without engaging the starting there is a click that comes from somewhere under the hood and now I am not hearing that click. What is this click and is it the problem? Any other suggestions or tips appreciated. I'm used to working on an old JD gasser so this newer diesel is foreign to me. Thanks in advance.
/ Help!!! Workmaster 55 Won't Start #2
:welcome: to TBN
I can't help you with your click but my backhoe clicks when I turn the switch on and its the fuel solenoid located inside the injector pump. It was a no click and a no start like yours but only occasionally. Luckily all it turned out to be was a loose wire connection on the spade terminal that operated the solenoid. Hope yours is something simple. Start with the simple things first and check wiring connections especially anything that has something to do with the fuel shutoff.
2013 KENWORTH T800 BOBTAIL VACUUM TRUCK (A65643)
2013 KENWORTH T800...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
2018 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2018 Nissan...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
