Help with X585 Error Code
/ Help with X585 Error Code #1
JJE64
X585
After plowing snow and shutting off/restarting the engine, my 2005 X585 shows an error code. The code seems to be "air/fuel calculation error".
Has anyone else seen this issue? Is there a known fix? I have changed the fuel filter and cleaned the air filter.
The tractor never loses power. And once the code appears I can clear it by cycling the tractor on/off.
Any advice/help is appreciated.
Thanks
JJE64
/ Help with X585 Error Code #2
I had a similar problem the other night after blowing snow for an hour with my 585. I hopped off the seat to open the garage door, and the engine died. I had to push it inside as it wouldn't crank at all. That had never happended before.
I didnt have any error code showing. I figured it must have been snow/mositure under the seat so the auto shut off was malfunctioning. I left it for a day to melt and dry off...and it started with no problem.
Sorry i don't have any advice...other than wait for spring to warm things up!
/ Help with X585 Error Code #3
Make sure all your connections are clean and take off the battery cables and fuses are clean. A loose/bad connection can cause a temporary fault that could trigger that. It's nothing major since it runs good (i.e. sensors, computer, etc). Check the simple stuff.
2018 Ford F-150 Ext. Cab Pickup Truck (A66736)
2018 Ford F-150...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A66734)
2025 BrushFox...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
CAT 963D 4-in-1 Bucket (A68134)
CAT 963D 4-in-1...
2007 CATERPILLAR 277B TURBO SKID STEER (A65056)
2007 CATERPILLAR...
