Buying Advice Help with Tractor purchase - newbie
   / Help with Tractor purchase - newbie
The Dealer is offering me a Landpride BB1284 (84") box blade (new) for $750 and a Landpride 1884 (84") rotary cutter for $1800 (slightly used). Are these good numbers? Thanks,
   / Help with Tractor purchase - newbie #62
I don't know anything about the mower other than it is not listed on the LP website, as well as the BB1284.
Pretty much anything that is less than $1500 is not going to last very long behind a 75hp tractor. You really need to be looking at a box blade that is around 1000lb minimum if you want it to hold up behind a bigger machine.
Just keep in mind that these implements are a lower cost for a reason. Typically bigger tractors equal bigger, heavier more expensive implements.
That's a good point. Do I really need 84" wide box scraper or rotary cutter? That might be overkill too. I hadn't thought about needing a lot more steel in the ground if you're putting 75 hp to it.
There are diminishing returns just like any engineering challenge. You can price yourself out of getting anything (or building it yourself - which is what I commonly do).
   / Help with Tractor purchase - newbie #64
I would look for a used Gannon box blade- lots of weight and strength, and as far as grapples go I am a big fan .
use it more than almost any thing else, even used it this morning to unload 17 large square bales @ 1200# each and then stack them 3 high in the barn, best multi-use tool for a tractor IMO...
Here is the rotary cutter:
RCR1884 Rotary Cutters | Land Pride
I'm guessing the box scraper is a 84" version of the BB12 series. Quite wimpy now that I look at it: BB12 Series Box Scrapers | Land Pride
I do have the option to buy his used Gannon Box Blade with hydraulic 3-way. I forget the size, but he said the blade is $4K+ new and the cylinders are $1K/set to replace. I can pick this up (not literally) for $1800.
   / Help with Tractor purchase - newbie #67
How wide is that grapple?
I believe the one on the M8540 is 6', not sure on the L5740.
As to the cutter and box scraper, both are too light duty for that tractor, I use a BB2584 on our M8540 only as a counter balance and I added weight to it, for any work I use the HR3584 at 1100 pounds. I would jump on the Gannon real quick. I paid about $4k for my LP which looks just like a Gannon.
I wouldn't want anything less than a RCR18xx, my preference is an RCR2672 for my L5740 and a 10' pull type on our M8540, we use a Woods DS1260, Bush Hog, Rhino etc. makes good cutters. I've worn out lighter cutters and prefer the heavier duty ones.
   / Help with Tractor purchase - newbie #68
   / Help with Tractor purchase - newbie #69
Gannon Box Blade with hydraulic 3-way doesn't make sense. Is it a box blade or a rear scraper blade?
If it is a box blade, it will have one hydraulic cylinder for raising and lowering the ripper mechanism. 3-way hydraulics would be on a rear scraper blade for angle, offset and tilt.
And, just to state the obvious, the hydraulic cylinder on the box blade requires one set of rear remotes, while the 3 cylinders on the scraper blade require 3 sets of remotes.
   / Help with Tractor purchase - newbie #70
I think that the seller may have a top & tilt set that should be going with the tractor anyway, and is considering those the other 2 cylinders. :confused3:
2017 Ford F-350XL (A57148)
2017 Ford F-350XL...
LINCOLN 225 ARC WELDER (A58374)
LINCOLN 225 ARC...
2025 J & C Suppliers Enclosed Trailer (A56859)
2025 J & C...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
