Help with tire sizing
/ Help with tire sizing #1
Kernopelli
Carterville, Illinois
Mitsubishi MTE2000D, Dig It 258 Mini Ex, Deere Z930A ZTR
My stock tires were 6.00-12 front, 8.3-24 rears. I mounted a set of 9.5-24's on the back and need to figure out the appropriate tire/rim size to keep the same F/R ratio.
The 6.00-12 has a circumference of 68.3". The 8.3-24 has a circumference of 115". I divide the rear circumference by front and come up with 1.68 so I assume that gives me a 1.68:1 ratio.
The new 9.5-24 has a circumference of 128", if I divide that by 1.68 I get 76" for my "new" front tire circumference, which would translate to what looks like a 7.00-12 tire ( 24" mounted dia.) like this 42D382,42D382GY,TITAN TIRE CORPORATION,712 7-12 7X12,GOODYEAR DYNA TORQUE II R1 TL,Tires 4 That
Am I figuring this correctly?
Appreciate the response, I too subscribe to the GTS ( Google that stuff) philosophy. I had already checked out comparison charts, I just can't find anything on calculating front to rear drive ratios. If anyone could look at my original post and see if I am correct in my calculations, I'd sure appreciate it.
/ Help with tire sizing #4
I can't tell from your descripition if you are figuring it out correctly or not. The number you want to match is called the "loaded rolling circumfernce". It is circumference measured on the ground as the distance covered in one tire revolution. It is different from from the arithmatic pi x diameter circumference.
rScotty
/ Help with tire sizing #5
rScotty
Just google "RCI chart" and look up which tires have the right circumference.
Thanks for the help everyone. I think I already have the correct tire circumferences, my concerns are: Did I use the correct mathematical process to figure the stock front to rear ratio and consequently, did I use the correct process to find the new front tire circumference to keep the tractor's F/R drive ratio? I'll recap:
The stock tires had circumferences of F/68.3" , R/115". I divided 115 by 68.3 and come up with 1.68( F/R ratio of 1.68:1). What I need to know- Is this the correct way to figure my tractor's F/R drive ratio?
My new rear tire's circumference is 128". I divided 128" by the 1.68 ratio and come up with 76". To keep my correct F/R size ratio I figure I will need new front tires with a 76" circumference ( 7.00-12 tires). What I need to know-Is this the correct way to figure what size tires I need to buy to keep the tractor's F/R drive ratio?
/ Help with tire sizing #8
Sure. Go for it.
Land Hero Mini Skid Loader (A66408)
Land Hero Mini...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
2023 Schulte FX3118 Batwing Mower (A66285)
2023 Schulte...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
