Help with new RT1160H
   / Help with new RT1160H #11
Good, But you MUST MAKE SURE THE PTO SHAFT IS NOT TO LONG!. If it is, and you raise the tiller up, you can wreck the PTO casing and or damage your tiller.
   / Help with new RT1160H #12
garth466 said:
Now it all makes less sense. What locks it onto the PTO shaft? The instructions say to engage the cardan shaft and check that it is perfectly locked on the tractor. The word "cardan" doesn't show up again anywhere in either the istruction book or parts catalog.
the cardan shaft is the little button, as Kenny said, make sure the shaft is not too long, it might cost you about $4k if it is....general way to tell is with every thing hooked up, see if you can connect/disconnect the pto shaft at the tractor at various lift heights
I've been able to disconnect at every position I've tried, so I should be good. I'm going to put a post-it on it so that the next time I hook it up, I will actually make sure that it will come off at every possible position.
   / Help with new RT1160H #14
ok, once you have verified the shaft is not too long, you never have to worry about that piece of equipment on that tractor again. just make sure every piece of equipment you buy you check before you work the first time.
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
2022 31 MINI SKID GRAPPLE BUCKET (A55745)
2022 31 MINI SKID...
2019 RAM 2500 Crew Cab Pickup Truck (A55788)
2019 RAM 2500 Crew...
SDLanch SDLLM500 (A53316)
SDLanch SDLLM500...
2006 Chevrolet Express 3500 Versalift Vantel29N 29ft Bucket Van (A55788)
2006 Chevrolet...
