Help with MF 12 baler
/ Help with MF 12 baler #1
MF165owner
VA
My #12 baler will not tie when I get the bale tight enought to handle. If I leave it loose it ties fine but you can not stack loose Hay. Is there any thing that I can do to make it tie the tight bale.
/ Help with MF 12 baler #2
What's it doing? breaking string? hanging knot? I don't know much about them but, I do have a model 12.
/ Help with MF 12 baler #3
I have a MF-124 two-twine baler. If that happened on the 124 I'd check the bill hooks to see if the jaws are working properly. The strands of twine may be slipping through or off the bill hook when you increase the bale packing level.
Used it Tusday It did all right. I rode on the baler while mom baled. It is still hanging on the bill hook just a little. Is there any thing that I can do to help that. It is causing the twin to strech some.
/ Help with MF 12 baler #5
There is an adjustment for the bill hook tension. If you look to right of the bill hook you will see a lock nut with adjustment screw. Back it off a 1/4 turn and see what happens. You can see it just barely by looking down from the top but it's easier to get at if the knotters are flipped up.
Thanks will try that Got some to bale later on in the week.
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A64553)
2014 Caterpillar...
2012 TROXELL 200BBL CRUDE TANKER (A65643)
2012 TROXELL...
2025 TP25 25in Hydraulic Post Puller Skid Steer Attachment (A64553)
2025 TP25 25in...
Club Car Emergency Cart (A64557)
Club Car Emergency...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
