Help with loosing screws..
/ Help with loosing screws.. #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I had my dads Stihl 031av all apart to clean it up a while back and found it was missing a few screws holding the side pieces on and the one holding the muffler on.. I bought new screws for the side pieces and made sure everything was tight before i started using it
I noticed that after only a little use one of the side screws has come out and that the muffler is loose again..
What should I use to keep from screws from loosening up? Obviously it has to be something that is non-permanent..
thanks
Brian
/ Help with loosing screws.. #2
Lock washers, Loc Tight.
/ Help with loosing screws.. #3
There are different grades of locktite.
Some can be 'cracked loose' with a simple spanner, and some need real effort to the point of virtually being permanant, so ask B4 buying.
/ Help with loosing screws.. #4
Loc tite blue and a couple of extra sets of all the screws you had to replace. Chainsaws vibrate which loosens screws then you lose screws. It's a fact. I buy bar nuts 10 at a time. Muffler bolts are always loosening. If I try to tighten too much I tend to break bolts
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
2022 Caterpillar 262D3 (A64126)
2022 Caterpillar...
24in. Terex Excavator Bucket with Teeth (A64194)
24in. Terex...
Chevrolet 2500HD (A63688)
Chevrolet 2500HD...
300 Gal Fuel Tank (A64127)
300 Gal Fuel Tank...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
