Help with loosing screws..
/ Help with loosing screws.. #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I had my dads Stihl 031av all apart to clean it up a while back and found it was missing a few screws holding the side pieces on and the one holding the muffler on.. I bought new screws for the side pieces and made sure everything was tight before i started using it
I noticed that after only a little use one of the side screws has come out and that the muffler is loose again..
What should I use to keep from screws from loosening up? Obviously it has to be something that is non-permanent..
thanks
Brian
/ Help with loosing screws.. #2
Lock washers, Loc Tight.
/ Help with loosing screws.. #3
There are different grades of locktite.
Some can be 'cracked loose' with a simple spanner, and some need real effort to the point of virtually being permanant, so ask B4 buying.
/ Help with loosing screws.. #4
Loc tite blue and a couple of extra sets of all the screws you had to replace. Chainsaws vibrate which loosens screws then you lose screws. It's a fact. I buy bar nuts 10 at a time. Muffler bolts are always loosening. If I try to tighten too much I tend to break bolts
Hutchinson Grain Auger (A64127)
Hutchinson Grain...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
429835 (A61166)
429835 (A61166)
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
Deutz-Fahr 6140 (A64126)
Deutz-Fahr 6140...
