Help with loosing screws..
   / Help with loosing screws.. #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I had my dads Stihl 031av all apart to clean it up a while back and found it was missing a few screws holding the side pieces on and the one holding the muffler on.. I bought new screws for the side pieces and made sure everything was tight before i started using it
I noticed that after only a little use one of the side screws has come out and that the muffler is loose again..
What should I use to keep from screws from loosening up? Obviously it has to be something that is non-permanent..
thanks
Brian
   / Help with loosing screws.. #2
Lock washers, Loc Tight.
   / Help with loosing screws.. #3
There are different grades of locktite.
Some can be 'cracked loose' with a simple spanner, and some need real effort to the point of virtually being permanant, so ask B4 buying.
   / Help with loosing screws.. #4
Loc tite blue and a couple of extra sets of all the screws you had to replace. Chainsaws vibrate which loosens screws then you lose screws. It's a fact. I buy bar nuts 10 at a time. Muffler bolts are always loosening. If I try to tighten too much I tend to break bolts
   / Help with loosing screws.. #5
Loctite 242 or 243 (blue) would be an option, also Loctite 222 (purple) is a
good choice it is commonly used in guns and gunsmithing.
242 is the normal blue 243 is more oil tolerant than 242, and it flows better IMO.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A53117)
2018 Mack PINNACLE...
2021 Bell B30E Off Road Dump Truck (A53117)
2021 Bell B30E Off...
2000 International Log Truck, Triaxle, Log Bunks (A52384)
2000 International...
City of Buckhannon - 2000 GMC 3500 Service Truck (A52384)
City of Buckhannon...
