Help with ignition wires!
/ Help with ignition wires! #1
7000 Ford
Ford 7000
I have no clue where these wires go on this ignition. Does anybody else have a clue?
/ Help with ignition wires! #2
Yeah, they go on all those little metal tabs 🤣
Sorry, couldn't help myself. No idea. It looks like you have more wires than tabs.
/ Help with ignition wires! #3
I’m not saying that this diagram is correct but see if it makes sense by following your wire’s.
It comes from a switch for sale on Amazon
/ Help with ignition wires! #4
Try to score a wiring diagram for your tractor. You could also try You Tube.
/ Help with ignition wires! #5
Post the part so we can get the terminal meanings and I’ll show you how to trace the wires back
/ Help with ignition wires! #6
More information would help. Is this a tractor you just got...like that?
There are different ways to go about it...but how I'd do it.
I'd get paper, pencil, multimeter, masking tape.
Tape about 2" over wires near connector ends. Number them 1,2,3,...
Meter on ohms, Rx1. Short leads...be sure reads 0 ohms. Now switch has 5 connectors. Measure 1 to 2, etc. Write down key in on position...1 has continuity to 3 (for example)...cranking 1 to 4.
Meter on DC volts. Ground black lead. Measure all wires. Say wire 1 measures 12.6 volts. Now touch wire 1 to 3...headlights come on. 1 to 4...engine cranks. (Write all this down!).
Now we know you want wire 1 to switch 1. Wire 4 to switch 4.
Wooden End Table (A64127)
Wooden End Table...
F-250 SuperDuty (A63689)
F-250 SuperDuty...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2011 Chevrolet Silverado Pickup Truck (A62613)
2011 Chevrolet...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
International S1900 (A63689)
International...
