Help with ignition wires!
/ Help with ignition wires! #1
7000 Ford
Ford 7000
I have no clue where these wires go on this ignition. Does anybody else have a clue?
/ Help with ignition wires! #2
Yeah, they go on all those little metal tabs 🤣
Sorry, couldn't help myself. No idea. It looks like you have more wires than tabs.
/ Help with ignition wires! #3
I’m not saying that this diagram is correct but see if it makes sense by following your wire’s.
It comes from a switch for sale on Amazon
/ Help with ignition wires! #4
Try to score a wiring diagram for your tractor. You could also try You Tube.
/ Help with ignition wires! #5
Post the part so we can get the terminal meanings and I’ll show you how to trace the wires back
/ Help with ignition wires! #6
More information would help. Is this a tractor you just got...like that?
There are different ways to go about it...but how I'd do it.
I'd get paper, pencil, multimeter, masking tape.
Tape about 2" over wires near connector ends. Number them 1,2,3,...
Meter on ohms, Rx1. Short leads...be sure reads 0 ohms. Now switch has 5 connectors. Measure 1 to 2, etc. Write down key in on position...1 has continuity to 3 (for example)...cranking 1 to 4.
Meter on DC volts. Ground black lead. Measure all wires. Say wire 1 measures 12.6 volts. Now touch wire 1 to 3...headlights come on. 1 to 4...engine cranks. (Write all this down!).
Now we know you want wire 1 to switch 1. Wire 4 to switch 4.
(4) Lion Hart 265160/18 Tires (A64127)
(4) Lion Hart...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
2013 John Deere 7200 R Tractor (A66285)
2013 John Deere...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
Danuser 3 Point Post Auger (A65640)
Danuser 3 Point...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
