Help with hydraulics on International 424
   / Help with hydraulics on International 424 #1
spd132
Looking at a 424 that I can buy well worth the money but the lift is not working. The owner, who I know very well, advised that hydraulics was working fine until he had a mechanic do some work where he had to take off hydraulic lines. From what I have read, the hydraulics could be air locked. If so, how do you bleed the system? This tractor is in very good condition and I would have already bought it, but I just don't want to have to dump a lot of money into the hydraulics if it is something else.
   / Help with hydraulics on International 424 #2
Usually cycling the hydraulics will bleed the system. Put the 3 pt. in the lift position, and work a/the remote lever(s) if it has any. I have even nosed my one Super C downhill to get it to pick up prime.
If it was the hydraulic manifold lines to the pump that were removed, could be possible an o-ring was lost too, causing it to suck air.
   / Help with hydraulics on International 424 #3
My 424 has a tee fitting at the flow control block and one of the tee ends there is a cap and I open it to bleed the air out with engine running. Make sure you cover cap with a rag and be ready to shut tractor off because one the oil gets there you can't over the pressure to screw the cap on.
8 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
8 Piece Mini...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
Stanley Hydraulic power pack (A56435)
Stanley Hydraulic...
