Help with hydraulics on International 424
   / Help with hydraulics on International 424 #1
spd132
Looking at a 424 that I can buy well worth the money but the lift is not working. The owner, who I know very well, advised that hydraulics was working fine until he had a mechanic do some work where he had to take off hydraulic lines. From what I have read, the hydraulics could be air locked. If so, how do you bleed the system? This tractor is in very good condition and I would have already bought it, but I just don't want to have to dump a lot of money into the hydraulics if it is something else.
   / Help with hydraulics on International 424 #2
Usually cycling the hydraulics will bleed the system. Put the 3 pt. in the lift position, and work a/the remote lever(s) if it has any. I have even nosed my one Super C downhill to get it to pick up prime.
If it was the hydraulic manifold lines to the pump that were removed, could be possible an o-ring was lost too, causing it to suck air.
   / Help with hydraulics on International 424 #3
My 424 has a tee fitting at the flow control block and one of the tee ends there is a cap and I open it to bleed the air out with engine running. Make sure you cover cap with a rag and be ready to shut tractor off because one the oil gets there you can't over the pressure to screw the cap on.
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
